G'day all
I have time off work to finally take my "finished" R34 down the quater on 15th Feb so thought I'd see if anyone is interested?
Let me know for those interested in meeting up down there.
Would be great to get a group of skylines to try and put a few V8's back in their box ;-)
http://www.motorplex.com.au/news.php?newsid=788&g=9&pg=drag
Cheers,
Brendan
https://www.sau.com.au/forums/topic/389809-wednesday-night-drags-15-feb/
  • Replies 44
yeah I'm just about ready for another blast.. payed for the SS license so might aswell get some runs out thumbsup.gif
come on there must be more peeps that want to race and see what their car can do ???
Here, here Richard!
Look forward to finally meeting you and hearing that 33 roar!
Surely we can get a good turn out this time - come on people it's not about what time you do, it's about getting amongst it, making some beautiful RB noise and having some fun in my opinion!
Here, here Richard!
Hmmmmm very tempting fellas, new clutch is now bedded in so might try join you two :yes:
Cool...
if its not bedded in properly know, it will be by the time you drive home on wednesday thumbsup.gif
Baaahhhh! Always bad timing! Car not quite ready yet - but I'll come down with some Pom-Poms and support the team!
Just finished installing the new suspension and tidying up a bit so I'm good to go ;-)
Look forward to catching up/meeting you all there fellas!
Wes - you and I have much goss to catch up on
Edited by Bren444
I hope its a nice soft set-up to allow it to squat.
rich's gtr has a very sexy roar to it you will not be disappointed to hear it. i need a new flywheel and clutch kit for one car and basically a motor rebuild on the other
Thats a bugger Michael, I have a couple of worn-out clutches in the shed, one has the standard flywheel if you are wanting one...?
And Matt, is there a Tutu with those pom poms :woot:
Well I've raised the rear height and it's on the softest setting but it's still pretty stiff so see how it goes.
I already had a bilstein sports kit which I've just replaced and that was a pretty good set up so I don't think there will be a huge difference with the race kit.
Might see if I can tee up a skid switch between now n then so I can practice doing warm up skids!!!:D
Pretty sure warmup skids are only of benefit if your running drag rubber unsure.gif somebody correct me if I'm wrong,
from my experience, once normal road tyres are hot, the grip goes down hill..
yep this has been my experience, especially on the track, once hot they are useless, heres what I found after a bit of Googling:
Burnouts are traditionally used to warm up a car’s tires before a drag race. Warming up the tires makes the rubber softer increasing traction and also cleans the tires of road debris like gravel – further increasing traction. Slicks or drag radials are needed for a burnout to have noticeable results on the track, as burnouts using street tires do little more than make smoke and destroy rubber.
All depends on many things.. Try it with and without, you normally get enough runs to try a few different ways of doing it. Personally I liked ~20psi in my tyres and a little spin, but then it was just good fun too. :D
As much as I would like to get back down there since the rules have changed, unfortunately my car doesn't want to hold power steering fluid anymore.. just one more thing to fix.
Yep the fun bit, that's the key to me :rofl:
Have managed to fit one up tonight, so will be doing skids for fun whethers theres benefit or not! Looking fwd to it.
Brendan you can do warmup skids matey - no excuse!
http://www.motorplex.com.au/media/docs/STREET_REGULATIONS_Final_291111.pdf
Street cars originally fitted with four wheel disc brakes and air bags can now go down to 10.00 without the loop, licence etc. Looks like my 32 can go down to 10.50 same, no airbag. Before it was lower than 12.00 that I was asked to leave.
Hell yeeeeeeaaaahh! baha I am all about making RB noise my friend ;-)
I'm hoping you fellas will be impressed with my new exhaust set up - It's the loudest non GT-R I've heard without an external waste gate.
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
