Hey guys got my Drifteks for sale/swap.
They are 17x9.5 +18, black.They have some gutter rash thats been painted so its not so noticeable. One pair of tires are basically new (about 100km done) GT radials 235/45/17 and the other pair are around 40% tread left.
They are also multi stud, 4 and 5 by 114.
Basically they dont fit under the guards on my cef, not keen on pumping the guards, and the Engineer is rather strict on protruding wheels.
So after $1000 outright or swap for higher offset wheels, i.e R33 gtr wheels, or anything around the 17x9 to 9.5 with a offset no lower than +25.
Will consider 18's also in similar widths (9-9.5, around +25 to +30).
sms 0400257530 or pm.
Cheers
Glen
https://www.sau.com.au/forums/topic/389827-driftteks/
Lol missed vital info, located in nowra, Nsw, work in wollongong.
Would you consider something like
Buddy Club P1's 17x9 offset +27 ???
Currently has 2x 235x45x17 and 2x 225x45x17 tyres. mismatched on my evo :-(
The Drifteks should fit comfortably over Brembos i think... I'm just concerned of the +18 offset as being too aggresive. Let me kno what u think
https://www.sau.com.au/forums/topic/389827-driftteks/#findComment-6210598
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
    • I hope that is not something that bad. From what i remember he said that only first gear is "hard" to get in and that he has couple of ideas what to try next but idk 😕  hope it is not gearbox out. I will let you know.
    • If it's not the hydraulics, it is probably gearbox back out. Usually as per @Duncan's post, or otherwise associated with not getting the throwout fork positioned correctly. All the way up to catastrophically bolting shit back together without it being aligned properly and wrecking the clutch/input shaft/flywheel/something else.
