  • Replies 68
Well Im going to add my two bobs worth...
I have got a PST carbon shaft in my GTR R34 it is the best there is.... you get what you pay for.. you want to go lighter then depending on power you will be buying another one as it will break...
I bought a ACPT shaft and I broke it in a week, it was shit, then they sent me another one as replacement it was suppose to be the 1200hp one, I could not even drive the car above 40 klms/Hr the vibrations were that bad, I rang them they said it had been balanced the service was piss poor and I was pissed off, so I sent it to a engineering shop to get rebalanced. So another $600 for the rebalance and it was ok... I Will never by another one from ACPT they make them for trust, nismo and all the other Jap brands.. they are crap.
By this time I put a Holinger in my car so I spoke to PST drive shaft in the US they custom made one and it is awesome.. good to talk to and the price was very reasonable, it will be better now the Dollar is $1.06 The gearbox will break before the shaft will.
Dont pm me asking stupid questions on the weight, cost or where do you get it, do your research as I did.
Such a helpful guy you are
:thumbsup:
Trent I also have a PST carbon shaft in my car and have fitted one to another car that you would know fairly well. Sold one to another guy and have never had a complaint from him. I also have another one here waiting to be fitted to another car currently in the build.I would recomend them as they were good to deal with and where reasonably priced individually but are flexible on price if you organize a group buy. Give me a call if you want contact details.
Just spoke with Mark at PST (sorry Dazmo, too early to call you).
Price is US$1099 so nearer AU$1025 with the currency around 1.08.
3 1/4" carbon tube which includes joints on each end, ready to bolt in to your car. Weighs around 12 lbs = 5.4kg.
rated to 1000 ft lbs of torque (1355 nm). Said he could make one rated to 1350 if need be for an extra couple of hundred bucks.
shipping likely to be around $150 mark.
Edit:
Torqline shaft failure load in excess of 4000nm.
I know which one i want. just need to find the extra $$$.
Edited by tk80
Edit:
I know which one i want. just need to find the extra $$.
My last dyno graph shows 1012.4 FtLb so I'm out for the PST shaft.
If you go Torqline let me know.....
Edit:
Thats awesome for the price. Will have to look into getting one for the gts-t.
Edit:
4000Nm... using same / comparable testing method?? that's a shitload more. Will be interested to see how they stand up to the torque from the higher-powered RBs, whichever route you decide to take.
4000Nm "failure load" is different from 1350Nm torque rating. 4000Nm is the breaking point of the Torqline, 1350Nm is the safe output for use of the PST.
What's the weight difference between the carbon and aluminum ones?
    • Right, its been a while for updating this car, but I made some small but important progress today. In the end I bought an Ecutek dongle from the Australian distributor Tunehouse (for local hardware support) but have gone with a remote tune from Racebox in the US (because they have done millions of these, and I could not find any tuner where I could access the tune anyway as they are all password locked). The App is reasonably easy to work with, but the PC software reminds me of Haltech's ECU Manager that you need to use with the Plat Pro ECUs, it is a nightmare.  Anyway, I sent the details over, got back a tune file and a request for data logs. I finally got a chance to access a private test track today as they want redline logs in 3rd and 4th, and have sent them back for the first round of reviews. The main difference in the tune is going from 1.0 (stock) to 1.3 bar (19psi), although I'm sure is a lot of other stuff in the background. Keeping in mind this is a dead stock car with 125,000klm, this is what the App's performance test claimed: Before After Interesting to note that both 400m tests had the same terminal speed (158klm/h) but different ETs. And no, the speed limiter seems to be higher than that at 186kl/h. Summary of the key logged parameters for the 3rd and 4th gear runs were: Those little turbos were certainly whizzing at 200,000rpm+.  Also I'm really not that excited about oil pressure 55psi at redline so I think I'll go thicker than 5w30 (nissan recommend 0w20....) and see if that improves it. Other than that (and the big boost spike....) everything looks good as a start to me.
    • Just one more post to show the final result and the original "janky" solution for a laugh. Everything feels really tight and no wobbling at all, very pleased 🙂
    • After drying a few days, time to put her back together
    • The hot exhaust light will come on not from just the cat being blocked, but it's just a temp sensor, and it's designed to warn you to not do things like park in long grass.   If you've been pushing the motor a bit, it can cause the light to come on.   Second if the cat is rattling, I'd suspect it's not blocked, but instead falling apart inside.   The easiest "fix" until you can get a cat put back in, is to unbolt your one, bash the rest of the insides out, and then bolt it back in.   For a daily driver/street car, I am in agreeance of put a cat in the car. If it were race car I wouldn't care if it were removed.
