hi guys, this issue has been happening more frequently over the past 2 months or so. i use to get the pop after trying to start before on cold days but it never gave a puff of smoke.
basically on cold start up or even after i stop driving and trying to start again after 30mins-2hrs, it is very hard to start.
it would crank, and feel like its going to start then it would pop and will not start, so i'd have to crank again and keep holding it and then it would start after sounding like a struggle, then a puff of white smoke would come out.
after googling, and doing some searching on here, it could either be leaking injectors or valve stem seals.
after about ~1.5years since the rebuild, i noticed there were some dirt residue around the injectors which i assume they were leaking an dirt has stuck to it. i do notice around the base of the injector where it sits in the plenum its wet, but it doesn't drip out fuel, is this normal?
anyone have an idea what it could be?
engine: rebuilt rb25det neo
ecu: haltech PS1000
injectors: hiflow standard injectors 600cc
any help much appreciated.
I check the start up issue it for u if u want. Best bet is to test the injectors on the bench and see if they dribble
Does it use any oil? Is there any oil residue on the spark plugs?
Do all spark plugs look the same?
sure, that would be sweet Jez, how do i save the map file to send to you? i got the software and cable on my laptop.
last service i did, there was no oil on the spark plugs,
the service before the most recent, plug #6 tip was white but the most recent change it was normal and all were the same.
    • Thanks for that Paul.  Do you think if I posted a picture you'd be able to remember where it went?
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
    • As above, you did refill the coolant and burp the system before running it again didn't you?
    • To be fair - you see the same thing for every clutch. There's always someone making an installation error.
    • Just saw this, redacted names. It's on a R33 GTS-t Facebook group. Looks like still teething issues.
