Hi Guys,
Decided to pull the Laurel out of storage and put it up for sale. Its been sitting in the shed for the last 2 years doing nothing at all since I've moved back to VIC, and since then I've had a child and just haven't had time to get out and work on it.
So at the moment I'm adding this for sale as a whole vehicle, it CAN NOT be registered and was bought into the country for RACE/RALLY only. If the vehicle doesn't sell in the next, say, month it will be COMPLETELY stripped out and parts sold individually.
to finish this vehicle off, all you would need to do is fabricate the cooler piping from the TB to the intercooler, and hook up the idle control solenoid, run the vacumn lines, Remote mount battery, then tune. Pretty simple stuff really.
Would also be tempted for trades of something interesting, I'm especially partial to S14s (had two already)
[email protected]
0447009897
03 53810849
Looking for offers around 16k
also have a near brand new car trailer that I can sell with it for 3k more (or 4k seperatly)
Heres the spec list:
Body
Paint is Pearl White, body has a few marks and small dents
Wonder Kit, all around.
AVS model 5 Rims, 18x9 +20 front (with 10mm spacers)
18x10 +18 Rear
225/40/18 front
235/40/18 rear
FRP bonnet, could probably do with repainting
Black tint all round
Interior
stripped and half the sound deadening removed
Recaro SR3 (red) drivers and passengers
Hydro handbrake (not fitted)
nismo knob
momo wheel
Defi Tacho, Boost, Water Temp, Oil Temp, Oil pressure
Apexi PFC
Greddy EBC
Racing Harness (not fitted)
Engine
RB25DET (series 2 motor)
Running on S1 loom as thats what was in the car, swapped sensors etc
Splitfire Coilpacks
Z32 AFM
Apexi RX6 turbo
Apexi Exhaust manifold
Apexi External Wastegate
Apexi Front pipe
3 inch exhaust
Frontwards facing plenum
80mm Throttlebody
550cc injectors
GTR cooler
Unknown Cams and headwork
metal headgaskit
Koyo Radiator
N1 waterpump
Custom oil cooler setup
Driveline
ORC twin plate clutch
RB25 gearbox
Tein Coilovers
Ikea Formula caster rods
Kazama Rear Camber arms
Kazama Rear toe rods
Kazama solid cradle bushes
2-way diff
Proper ABS removal (Non ABS reservoir fitted from R33, as well as brake lines from an R33)
R33 Front callipers
Vid of vehicle Idling
https://www.sau.com.au/forums/topic/389934-c35-laurel-track-only/
  • 3 weeks later...
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
