Hi Guys,
Decided to pull the Laurel out of storage and put it up for sale. Its been sitting in the shed for the last 2 years doing nothing at all since I've moved back to VIC, and since then I've had a child and just haven't had time to get out and work on it.
So at the moment I'm adding this for sale as a whole vehicle, it CAN NOT be registered and was bought into the country for RACE/RALLY only. If the vehicle doesn't sell in the next, say, month it will be COMPLETELY stripped out and parts sold individually.
to finish this vehicle off, all you would need to do is fabricate the cooler piping from the TB to the intercooler, and hook up the idle control solenoid, run the vacumn lines, Remote mount battery, then tune. Pretty simple stuff really.
Would also be tempted for trades of something interesting, I'm especially partial to S14s (had two already)
[email protected]
0447009897
03 53810849
Looking for offers around 16k
also have a near brand new car trailer that I can sell with it for 3k more (or 4k seperatly)
Heres the spec list:
Body
Paint is Pearl White, body has a few marks and small dents
Wonder Kit, all around.
AVS model 5 Rims, 18x9 +20 front (with 10mm spacers)
18x10 +18 Rear
225/40/18 front
235/40/18 rear
FRP bonnet, could probably do with repainting
Black tint all round
Interior
stripped and half the sound deadening removed
Recaro SR3 (red) drivers and passengers
Hydro handbrake (not fitted)
nismo knob
momo wheel
Defi Tacho, Boost, Water Temp, Oil Temp, Oil pressure
Apexi PFC
Greddy EBC
Racing Harness (not fitted)
Engine
RB25DET (series 2 motor)
Running on S1 loom as thats what was in the car, swapped sensors etc
Splitfire Coilpacks
Z32 AFM
Apexi RX6 turbo
Apexi Exhaust manifold
Apexi External Wastegate
Apexi Front pipe
3 inch exhaust
Frontwards facing plenum
80mm Throttlebody
550cc injectors
GTR cooler
Unknown Cams and headwork
metal headgaskit
Koyo Radiator
N1 waterpump
Custom oil cooler setup
Driveline
ORC twin plate clutch
RB25 gearbox
Tein Coilovers
Ikea Formula caster rods
Kazama Rear Camber arms
Kazama Rear toe rods
Kazama solid cradle bushes
2-way diff
Proper ABS removal (Non ABS reservoir fitted from R33, as well as brake lines from an R33)
R33 Front callipers
Vid of vehicle Idling
https://www.sau.com.au/forums/topic/389934-c35-laurel-track-only/
  • 3 weeks later...
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
