I normally would not reply to a PM this way but this silly site would not let me reply in the normal way . This is about a GT3782R on a 25 BTW .
To the OP , these are pretty big turbos for a 2.5L engine and its not surprising it came on boost ~ 3500 revs . If your mate was using a std cast TS manifold it was probably going to be a limiting factor even though these turbos have the TS T3 (Euro T4 actually) mounting flange .
Now these GT3782Rs were intended to be American aircraft carrier / ute "pickup" truck turbo upgrades and I think from memory they have the lower temp diesel spec turbine material too . Their Stage 1/2/3 were mainly compressor wheel options the largest (st 3) being the 88mm 52T from the GT4088R . The st 2 is same wheel as the GT3582R and stage one I think an 82mm 50 T version of st 3s wheel . Being a 7/7 bladed wheel in 82mm I'm guessing its stage 1 .
Most GT3776s and GT3576s are big frame plain bearing turbos but there are a few BB units on some Hino and Isuzu trucks . In any case you can now get them in the smaller GT25 BB cartridge size because I think the later Ford Typhoon XR6s use this one .
Ultimately most find that truck turbos are a PITA mainly because the housings aren't really suitable unless you intend to fabricate everything around the turbo or need a certain housing size not available as an aftermarket car part .
Personally I think you are better of putting something on an RB25 that boosts closer to if not a little under 3000 revs so you get some benefit from the thing more often . GT30 based ball bearing turbos seem to work pretty well though I'd avoid the GT3082R/GT3040R version unless its the HKS spec one because the Garrett marketed ones seem to be a bit lazy to come on boost .
I have no experience with Holset turbos but others here do , just remember the time/effort/money involved in fitting diesel truck turbos because it can be a painfull way to find the result is not what you expected .
Hope this helps , cheers A .
Edited by discopotato03
https://www.sau.com.au/forums/topic/389975-gt3782r-pm/
well I have the turbo sitting on my shelf. Its off an 8lt Scania LPG bus. But after plotting out the flows to make any sort of power it was way out of it's efficency zone due to the diesel trim. Part of me wants to rip the 82mm wheel off and put an 88mm wheel and a normal exhaust housing on it since I already have the turbo. The other half is saying buy a TD06H 25G and put the 3782 on a mates diesel Patrol or Land cruiser which it would be more suited to. So many choices, so little money.
https://www.sau.com.au/forums/topic/389975-gt3782r-pm/#findComment-6212238
To the OP , sorry but I went back and re read and I had though you had a GT3782R which is a ball bearing diesel pickup upgrade family .
If what you have is the plain bearing one then I'm not surprised it was laggy . While some used a 52 trim 82mm GT40 compressor the compressor housings weren't always port shrouded and that makes a difference .
If you had access to the big shaft GT35 turbine that would help but then the turbine housing is no good . I'm not sure what AR ratios Garret made GT40 housings that were profile machined for GT35 turbines but I think they were pretty big . I think I have a GT3576 plain bearing turbo kicking around here somewhere but from memory it has a chipped turbine and the housing is something like 1.16 AR ratio .
Honestly the BB ones are better and in time the Hino/Isuzu tax will come off them . The plus points would be a usefull TS turbine housing AR ratio and a suitably sized port shrouded compressor housing .
Possibly the cheapest ball bearing big frame turbo is a T04 60-1 or the same thing with the T04R compressor marketed as a T04Z , I think HKS marketing came up with the Z = BB in this case
A .
https://www.sau.com.au/forums/topic/389975-gt3782r-pm/#findComment-6212952
Hey Ash,
I currently have fitted to my RB30 a hypergear bush bearing 3576 which is laggy for some reason unknown to me. (it's currently at a well known shop here in Perth getting a look over with a fresh set of eyes to see if I have stuffed up some where on the build). The GT3782 I'm not 100% sure if its BB or bush, thats 1 thing I have never noticed or checked. Shouldn't be too hard to figure out. Also to my knowledge it isn't a port shrouded cover. If I remember I'll measure the shaft size and figure out some more specs and see what it options there are for converting it to something more useful.
Let me know if the pics don't load and I'll reattach them again
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=msg&attach_id=371535
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=msg&attach_id=371536
http://www.skylinesaustralia.com/forums/index.php?app=core&module=attach&section=attach&attach_rel_module=msg&attach_id=371537
https://www.sau.com.au/forums/topic/389975-gt3782r-pm/#findComment-6213625
Thanks for the replies.
As we all know, some of garret pump turbos are out of flow from calculations, but still making power.
Just a thought.
What do you rekon would be possible max power with GT3782 on rb25 ? And its journal bearing.
https://www.sau.com.au/forums/topic/389975-gt3782r-pm/#findComment-6214724
Just a thought.
Well that map in post 5 shows the maximim airflow (on that map anyway) as 55 pounds of air which roughly equates to 550 hp . My old rule of thumb was to subtract 10% which lands it around 495-500 . I think what cuts it a tad short for an 82mm GT40 compressor is the lowish AR of its housing and to some degree its trim size . I think I have a map somewhere of the GT4082 and its possibly similar with I think a 50T version of that wheel . Better looking map though .
Rifles through maps - no its actually a bit more at 570 odd - 10% = 513 . I'd have to look but I think they used a port shrouded compressor housing in the same ratio .
That aside as usual the hardest parts of getting any turbocharger "right" are the turbine and turbine housing . If you get these in the ballpark the compressor end is reasonably easy - provided a suitable range of wheels and housings are available .
Hopefully one day these larger frame center sections , BB ones , will be more readily available and people should be able to play around with turbines and compressors to get what they want . We wouldn't have as many issues with the smaller GT25 BB frame units if Garrett would gives us a wider selection of turbine trims (ie 78T GT30/GT35) AND a range of twin scroll twin integral gate turbine housings . If they can do it for Evo 10 GT3076Rs they can do it with twin inlet T3 flanged turbine housings as well ditto T4 flanges .
A .
https://www.sau.com.au/forums/topic/389975-gt3782r-pm/#findComment-6214834
  • 8 months later...
    • Yep super expensive, awesome. It would be a cool passion project if I had the money.
    • Getting the setup right, is likely to cost multiples of the purchase price of the vehicle.
    • So it's a ginormous undertaking that will be a massive headache but will be sorta cool if pulled off right. And also expensive. I'm sure it'll be as expensive as buying the car itself. I don't think you could just do this build without upgrading other things to take the extra power. Probably lots of custom stuff as well. All this assuming the person has mechanical knowledge. I'm stupid enough to try it but smart enough to realize there's gonna be mistakes even with an experienced mechanic. I'm a young bloke on minimum wage that gets dopamine from air being moved around and got his knowledge from a Donut video on how engines work.]   Thanks for the response though super informative!
    • Yes, it is entirely possible to twincharge a Skyline. It is not....without problems though. There was a guy did it to an SOHC RB30 (and I think maybe it became or already was a 25/30) in a VL Commode. It was a monster. The idea is that you can run both compressors at relatively low pressure ratios, yet still end up with a quite large total pressure ratio because they multiply, not add, boost levels. So, if the blower is spun to give a 1.4:1 PR (ie, it would make ~40 kPa of boost on its own) and the turbo is set up to give a 1.4:1 PR also, then you don't get 40+40 = 80 kPa of boost, you get 1.4*1.4, which is pretty close to 100 kPa of boost. It's free real estate! This only gets better as the PRs increase. If both are set up to yield about 1.7 PR, which is only about 70 kPa or 10ish psi of boost each, you actually end up with about 1.9 bar of boost! So, inevitably it was a bit of a monster. The blower is set up as the 2nd compressor, closest to the motor, because it is a positive displacement unit, so to get the benefit of putting it in series with another compressor, it has to go second. If you put it first, it has to be bigger, because it will be breathing air at atmospheric pressure. The turbo's compressor ends up needing to be a lot larger than you'd expect, and optimised to be efficient at large mass flows and low PRs. The turbo's exhaust side needs to be quite relaxed, because it's not trying to provide the power to produce all the boost, and it has to handle ALL the exhaust flow. I think you need a much bigger wastegate than you might expect. Certainly bigger than for an engine just making the same power level turbo only. The blower effectively multiplies the base engine size. So if you put a 1.7 PR blower on a 2.5L Skyline, it's like turboing a 4.2L engine. Easy to make massive power. Plus, because the engine is blown, the blower makes boost before the turbo can even think about making boost, so it's like having that 4.2L engine all the way from idle. Fattens the torque delivery up massively. But, there are downsides. The first is trying to work out how to size the turbo according to the above. The second is that you pretty much have to give up on aircon. There's not enough space to mount everything you need. You might be able to go elec power steering pump, hidden away somewhere. but it would still be a struggle to get both the AC and the blower on the same side of the engine. Then, you have to ponder whether you want to truly intercool the thing. Ideally you would put a cooler between the turbo and the blower, so as to drop the heat out of it and gain even more benefit from the blower's positive displacement nature. But that would really need to be a water to air core, because you're never going to find enough room to run 2 sets of boost pipes out to air to air cores in the front of the car. But you still need to aftercool after the blower, because both these compressors will add a lot of heat, and you wil have the same temperature (more or less) as if you produced all that boost with a single stage, and no one in their right mind would try to run a petrol engine on high boost without a cooler (unless not using petrol, which we shall ignore for the moment). I'm of the opinnion that 2x water to air cores in the bay and 2x HXs out the front is probably the only sensible way to avoid wasting a lot of room trying to fit in long runs of boost pipe. But the struggle to locate everything in the limited space available would still be a pretty bad optimisation problem. If it was an OEM, they'd throw 20 engineers at it for a year and let them test out 30 ideas before deciding on the best layout. And they'd have the freedom to develop bespoke castings and the like, for manifolds, housings, connecting pipes to/from compressors and cores. A single person in a garage can either have one shot at it and live with the result, or spend 5 years trying to get it right.
    • Good to know, thank you!
