Hey all
Putting my S13 track car up for sale, Was a work in progress but selling off some of my toys to do other things.
Car is nearly 100% complete, just needs a few small things dont and away you go. Will make a great drift car!
Car runs and drives no worries, needs exhaust modified slightly as it just touches body and also needs front bar fitted but comes with car.
Details below -
ITEM : S13 track car with rb20det
CONDITION : good
INFO :
RB20DET
NISTUNE ECU ( TUNED FOR MODS ON CAR CURRENTLT – 12 PSI – 200rwkw )
R34 NEO TURBO
HKS FRONT MOUNT
17” ROTA WHEELS
SOLID ENGINE MOUNTS
Z32 AFM
K&N FILTER
MODIFIED “ X “ MEMBER ( EXTRA STEEL SUPPORT BRACING )
MODIFIED REAR CRADLE ( EXTRA STEEL SUPPORT BRACING )
THERMO FAN
NEW TIMING BELT
NEW WATER PUMP
040 INTANK PUMP
7 POINT CAGE
BUCKET SEAT
MODIFIED HANDBRAKE
R33 GTST BRAKES
H/D CLUTCH
KEI OFFICE COIL OVERS
CUSCO ADJUSTABLE CASTER ARMS
CUSCO ADJUSTABLE LOWER ARMS
CUSCO FRONT AND REAR STRUT BARS
CUSCO 2 WAY DIFF
MODIFIED KNUCKLES
EXTENDED STEERING ARMS ( CAR TURN ON ITSELF )
SOLID CRADEL BUSHES
GTR REAR SWAY BAR
Heaps of other bits and peices included as well.
CONTACT : PM me
PICS : Will MMS to those who want them.
PRICE : $5500
Cheers
https://www.sau.com.au/forums/topic/389986-s13-track-car-rb20det/
Hey all
Details below -
CONDITION : good
INFO :
RB20DET
R34 NEO TURBO
HKS FRONT MOUNT
17" ROTA WHEELS
SOLID ENGINE MOUNTS
Z32 AFM
K&N FILTER
MODIFIED " X " MEMBER ( EXTRA STEEL SUPPORT BRACING )
THERMO FAN
NEW TIMING BELT
NEW WATER PUMP
040 INTANK PUMP
7 POINT CAGE
BUCKET SEAT
MODIFIED HANDBRAKE
R33 GTST BRAKES
H/D CLUTCH
CUSCO 2 WAY DIFF
MODIFIED KNUCKLES
SOLID CRADEL BUSHES
GTR REAR SWAY BAR
CONTACT : PM me
PRICE : $5500
Cheers
Hey mate, where are you located
wow that parts list is impressive, good price really
so whats left to be done? whats your estimate on cost to complete? and y is it track only ? defected? written off ? can it ever be registered again?
no doubt thats a great price for this car
Its a good car, Was imported as a race rally only from what previous owner whom i bought the shell from stated.
Only needs a couple things done to be 100% finished-
Needs front bar fitted and supports for this fitted ( front bar comes with car )
Needs exhaust modified slightly ( touches body and needs to be angled slightly lower )
Couple other small clips and wires need to be tied and replaced.
Car is completly stripped ( besides dash and seat )
Good price considering car owes me fair bit more then what im asking.
Cheers
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
