I might sound stupid asking some of these questions but I have a thirst to learn so here goes...
1.I read this sentence in Zoom. 'The motor is dry-sumped to prevent oil starvation during its insane launches' What does dry-sumped mean?
2.'The heads have been ported and polished and fitted with Escort Racing double valve springs and titanium retainers' What's involved in porting and polishing heads? Making them bigger??
3.I hear ppl talking about valve springs, what are they, what do they do?
4.How does an air-shifted transmission work?
5.What are conrods, what do they do?
6.What in the bloody hell does a headgasket do? Why do you need a thicker one when running higher boost? What materials are used and which ones are best to use?
7.The how, what & why of dump pipes.
I've numbered them to avoid confusion and generally make things easier to refer to. I'm sure I'm not the only one that will benifit from the answers so bring it on ppl.
Oh and thanks in advance :P
https://www.sau.com.au/forums/topic/390-seven-questions/
dry sumped mean exteranl oil supply for better flow.
porting is when you make the inlets and out lets of a head bigg so more air can get in and the air can get out faster after the explosion. the valve springs and the the thing on top of the valves that push them closed so an explosion can take place. you up grade then when you have a higher rev limit cause instead of up to 700 explosions a minuite there are 8000 or 9000. up gradeing generall mean stiffening them.
air shifted trans don't really know but at 10 nto an option for the street.
conrods join the piston to the crank.
the head gasket seals the surface between the head and the block a thicker one lowers the compression so you hcan have a biigger explosion in the combustion chamber with out pre ignition.
the dump pipe question
they are better cause they get rid of the gas quicker after the explosion than stock ones. cause they separate the the exhaust gasses.
any more questions
meggala
https://www.sau.com.au/forums/topic/390-seven-questions/#findComment-11362
any more questions
meggala[/quote:fb18fa6b9c]
I knew you'd come through steve, cheers.
...so re the dump pipes, is it just a type of exhaust manifold but with better flow capabilities? why/how do they seperate the exhaust gasses?
https://www.sau.com.au/forums/topic/390-seven-questions/#findComment-11363
    • I drive the Tiguan much harder than the Skyline in all conditions, because it just grips and hooks, unlike the R33 shit box
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
