I have wound up the boost in my GTST R33 to 10psi with a turbosmart manual boost control valve and now it has a big flat spot and sometimes hesitates.
I have changed the plugs to 0.8 gap ones and have tried resetting the ecu. The ecu reset sometimes makes a big difference but only for that run and goes back to running like a dog when i turn it back off and on.
Any suggestions?
cheers
nick
96 GTST r33
cat back exhaust
sports panel filter
and stuff.
You've encounted the flatspot that everyone hates :D;)
From what people have found is that it's the ECU either retarding the timing heaps for some reason, or the AFM is maxing out for a spit second.
I know what your feeling, and it's damn frustrating. From what I've read a S-AFC helps with the problem. Not much else can be done sadly :D :D
Otherwise it's a replacement ECU.
Everyone will encounter this characteristic unfortunately.
It's S-AFC or PFC etc to get rid of it and also increase power by leaning out the mixtures at the top end as the std ecu richens the fuel when it detects a boost increase.
Cheers
does the factory ECU actually richen the mixture when it detects increased boost at the top end/high rpm only or does it richen the mixture evenly across the rpm from the moment turbo spolls up?
is this flat spot that bad and does everyone encounter it - I was about to install a blled valve next week to take it to 10psi but now.......????
Should I if it means I will have a big flat spot??? Will installing the bleed give me an increase in performance???
thanks guys
Originally posted by -Joel-
Slap a bottle of Octane Boost... Nulon Pro Strength.. 7 Points.. :) for around $20 or $16.95 at KMart.
Joel, don't waste the money on the 'so-called octane boosters' when they say upto 7 points they reffer to an octane increase maximum of 0.7 RON based on the lowest octane unleaded fuel it's boost is less on ultimate 98 and others. Toluene is a real octane booster:D
thanks guys
Most people will encounter some sort of flat spot when the boost is increased.
But believe me - the flat spot isn't really that bad compared to the increase in performace you get :uh-huh: :uh-huh: :burnout:
Mine Doesn't.. :)
But thats because its an R32.
What are the differences between the RB20DET's ecu and the RB25DET's ecu to make the RB25det's take out so much timing and over fuel so much.. I really can't understand this.
Or is it because of the crappy fuel in Aus and the RB25det's higher comp ratio doesn't run as well as the RB20det's.
Joel,
I'm really not sure about that one. I know that the R32 ECU has bad ignition maps (for the RB20det), I'd say this is partly becuase of the lower quality fuel we use here. And the R33 ECU has bad ignition and fuel maps (for the RB25det), again, partly becuase of the fuel we use.
But I also read somewhere that Nissan made the maps to overfuel while on full boost to keep everything cool (piston tops etc.) So maybe it is due to the factory maps and us using lower RON fuel just makes it worse???
Not sure
J
Yes you have to re-write it to suit obviously.
You can do the same with the RB20DET ECU for the R33 but you also have to make up a circuit to read the rpm and switch the solanoid on/off for the vct.
There was a discussion either here or on SDU about it.
I think it was in a Microtech discussion. Freebaggin was discussing (hehe) with the bloke.. Can't remember his alias but.
Yepp - I understand that it needs rewriting. But what about the wiring??? Any ideas if the plugs and pinouts the same??
Thanks
J
I also intend to increase boost to 10 or 11psi but my exhaust is limiting so can't go more than 9psi at the moment. Secondly my boost bleed valve setup was not very correct. Nigel from ICE told me I had to block off the solenoid(?? is it correct) so that it's somewhat isolated from the new system, otherwise the ECU will keep hesitating.
However I've just got the HKS dragger back exhaust now, and next do I have to get a hi-flow cat to attach it? Here's a info phrase from Taka-kaira "They are designed to integrate into the factory exhaust system by bolting up to the factory b-pipe".
What's this b-pipe? Is it the section with resonator after the cat?
thanks guys
I wouldn't worry about it, I have a bleed on mine set to 10 PSI and it goes great. I have not noticed any flat spot at all and the performance increase at 10PSI is well worth it.
    • Do Alan and Keith work on Skylines now? I remember buying stuff from them when I owned my Ralliart Lancer a few moons ago. Definitely genuine guys and be excellent if they dealt with the skyline platform as well.
    • Hey all, I'm Gaston from Sydney's West.  I was a member on here when I was a younger lad and owned a mint R33 GTS-T. Ended up selling it and getting married having kids (yadda yadda) we all know how the story goes. Now I'm back with the intention to get my midlife crisis (dream) car ... a R35 GTR.  You'll see me about asking questions and searching the forums. Good to be back and can't wait to get back an Import again.
    • I have to put something here in order to post the photos. From what I could gather there's more enthusiasm for modified cars now than there has been for years. There were probably more younger people there than older (me included lol) which was a good sign.  It did seem like the record least amount of representation of the 90's era hero cars on display though. Like maybe one or two examples of S-chassis Nissans, and maybe 3 or 4 R-chassis. By comparison there were a lot of Civics from that era but in all there were about 10 - 12 EG/EK Civic Type R.  Euro exotics are always there in large numbers, led by Liberty Walk...... say what you will about kids using markers to scribble on a Ferrari F40, it did seem like a stunt to infuriate Ferrari enthusiasts, or Ferrari itself. I wonder if there's something more to it. Either way LBWK have done some heinous things to a Lamborghini Miura this time. They should stop now.
    • Engines and drivelines are not war stoppers for me mate, busted arse bodies and un-obtainium parts and panels are though Both cheap Brumbies I looked at had trashed tubs and a fair bit of rust
    • Stock O2 sensors are narrowband. They're useless once you're away from stoich. IE, useless for what you're trying to do. 10:1 will read the same as 14:1 from the stock O2 sensors. That is, they'll read rich. The same level of rich.
