Time to sell this one once and for all. (Dan, pls call me.)
R33 Gtr 1995 GTR in white. 45,000kms with books and receipts of all modifications. Previous power with N1 Turbo's and standard bottom end was [email protected]. With current setup and HKS 2530, I have yet to get a final tune.
Ran [email protected] when first arrived. Never ran at a higher boost.
HKS POWER FILTER KIT
HKS KANSAI 80EA/F Meter (Z32)
HKS GT2530 Turbine
HKS GT Manifold
NISMO Turbo Pipe
NISMO Front Pipe
TANABE Racing Medallion Muffler
HKS 1.2mm Metal Head Gasket
HKS Engine Gasket Kit
HKS Step 2 Camshaft (in264/out264)
HKS Cam Adjusters
TOMEI Valve Springs
NISMO N1 Pistons (0.5 larger)
NISMO FUEL PUMP
SARD 555cc Injectors
CUSCO Oil Catch Can
HKS EVC III Boost Controller
HKS Oil Cooler
HKS Remote Oil Filter Kit
HKS Intercooler
HKS Intercooler Piping
YOSHIO FACTORY Racing Radiator
CUSCO Radiator Cover
NISMO Thermostat
NISMO GMAX II Twin Plate Clutch
HKS Kansai Attessa Conroller
APEX’i Power FC & Handset
OHLINS Racing Suspension (Heigh/Damper)
NISMO Circuit Link & Bushes
NISMO Circuit Link Castor Rods
AVS Model 5 (19x10 F/R) 275/30/19
NISMO 320 Speedo Meter (white)
NISMO Center Meter (white)
HKS ETC
HKS Drag Controller
HKS CAMP with Junction Box
VSpec rear diff
APEX Boost Meter
APEX Exhaust Temp Meter
TRUST Pillar Mount
APEX ECV
CUSCO Strut brace
98 Series 2 Front Lip
N1 Intercooler Duct
N1 Bonnet Lip (Not fitted)
RECARO SPG II (2xRed) on top of the standard seats,
Apex'i REV/SPEED (blue version)
TRUST Grex gear knob
MOMO wheel
NISMO Oil cap
NISMO Rad cap
CUSCO Master Brake Stopper
CUSCO Steering Shaft Extension
HKS Type 0 T/Timer
Nismo EXEDY Twin Plate (extra for rebuilt)
BLITZ Blow Off Valve x 2 (Removed)
ALPINE Competition Head Unit
ALPINE 2 way Splits (Front/Rear)
ALPINE 6 Stack
PANASONIC Flat screen
Current offer is over 50 to someone is WA. IF you are a serious enquirer, call me on 041 340 8981 or PM me. Thanks.
https://www.sau.com.au/forums/topic/39001-r33-gtr-modified/
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
