You can't be serious take all the boost out of it if you get two fans put them side by side and stand in front of them the big fan will flow more air then the smaller one it's same going for compressor wheels if you have a stock comp wheel against a gt30 wheel the gt30 comp wheel is bigger and will flow more. On my 20 the rb25 turbo got me 170 kw at 14 pound then I installed a td06 and made 220 kw on 14 pound the motor didn't decided oh yay new turbo I'll make power now it's the fact the td06 flowed heaps more for the same boost
Not if whatever's controlling the fans is set to slow the bigger one down once airflow reaches a certain point....
  • Replies 43
Posted Images
How?
You can run the biggest turbo you want, if the actuator is only set-up to run 10psi into the inlet system, then the turbo will only FLOW enough air into that restriction to make 10psi. It can't cram 10 times the volume of air into the same engine without increasing the pressure?
Read my previous post about the ENGINE + TURBINE being the restriction that your boost is working against and try to understand it. The actuator has nothing to do with this argument.
I am trying to understand, genuinely.
The engine restriction hasn't changed, the valves/manifolds/throttle body etc still pose the same restriction to the incoming air as they did before. The gains are made by the engine not working as hard to make the same "boost", lower intake temperatures etc?
Yuh. Big turbo = big hole to blow the exhaust gas through. If you have a big hole, then to maintain the same backpressure, you must blow through more gas. Or, the other way to look at it is, if you start with the big hole at, say, 10 psi back pressure, and make the hole smaller, then the amount of gas that will flow through the hole goes down. If you want to maintain the same gas flow through the hole, then you need to increase the backpressure.
So this is all a little complicated by the fact that our "hole" consists of both the engine and the turbine section (connected in series)....but it is still the same result in the end. If the engine remains the same, and you change the restriction presented by the turbine, then you change the restriction presented by the engine and turbine together.
And of course, we have to ignore all the other bits about when the boost will start, when it will run out of puff, etc etc.
Lower intake temperatures and all that jazz can and wil play a part, but for the sake of the thought experiment, you can ignore all those, assume that they remain the same for the big and the little, if they're both running at 10psi boost and somewhere good on each of their compressor maps.
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
