Hi guys,
We took our R32 GTR out to the circuit last weekend and everything was great until we got the car home and up onto the axle stands to inspect everything.
When we took the front tyres off we noticed the inside wall of the tyres was starting to come apart (see pictures)
We don't feel we ran them too low pressure wise (we started off with 28 psi cold) and then worked towards a 32psi hot on all four tyres.
There's no visible damage to the outside wall of the tyres
The main tyre that is really bad is the left hand front tyre (inside wall), the two main almost hairpin corners at the track are right hand corners and the track is predominantly right hand corners and quite high speed.
Any thought as to what has caused this? The New Zealand Michelin Motorsport tyre distributor has told us we ran the pressure too low which we dispute.
Tyre size is 240/640R17
Prior to this session at the track the slicks had done twelve laps.
https://www.sau.com.au/forums/topic/390037-michelin-slicks-malfunction/
Rubbing wasn't the issue if you look at the last two pictures you can see the writing on the side wall perfectly untouched and also the ribbed lines the run across the sidewall.
So what was the days temperature, any idea on track temp, camber and toe settings
We have been having the same issues with another tyre over here on V8 touring car only on hot days and extreme loads.
Don't try and run the tyres again chords are broken
If you are sure pressures were correct, pending on camber and toe settings, tyres look to have been very hot? - if not, I would say - its a tyre case issue
Hi guys,
Thanks for the replies so far chaps,
To answer a few questions in no particular order :)
- No pyro reading as we don't yet own a pyrometer
- The temperature on the day was no more than 20 degrees, it was an overcast day so not too hot. Not sure on the temperature of the track surface itself
We started the day with 28psi cold all round and worked from there We were aiming for 32psi all round hot and were pretty close to that after letting one or two psi out after our first session. We took pressure readings immediately after pitting the car and took note of them. (off the top of my head the highest reading I would have seen was 34psi hot and the lowest 32psi hot)
There is very slight rubbing on the front plastic wheel arch liner but the is only on near full lock and only affects the outside wall of the tyre.(there's no way we would see anywhere near full lock at this track)
If there was rubbing elsewhere surely that would show up on the tyre itself wouldn't it? There is very little evidence that I can see looking at the pictures that I can see.
Picture of the car (sitting far too high as we had just put new springs in the front)
Camber 4 degrees, caster almost 7 degrees, Front toe 0mm
I have seen that before with that size and compound tyre - even with brand new stock - especially on powerful cars.
I always recommend 270 68 18 for the R32 GTR. It's the rear tyre of the old Porsche Cup cars (not the Carrerra Cup 30 68 18 or GT cars as in Cup S and Cup RS 31 71 18)
It's looks like a hinge joint failure. Yokohama has a similar problem in the v8 brute ute class hence why they have little front end camber.. I've had this happen before at over 3.5 deg
On an off note if you can afford new slicks why not a cheap pyro?its one of the most important setup tools in racing
Edited by Fatstig
Hi guys,
Thanks for the insights :)
To answer a few more questions.
- blackrex, we've not had the tyres off the rims yet so aren't sure but should go ahead with removing them as they're only good for the bin now.
- Munroman, have you managed to fit a 680 rolling diameter rim under an R32 GTR? We'd love to go down this path as the Porsche Cup slicks are a dime a dozen over here. We did look into this before we went for 17"s but were told a 270 68 R18 wouldn't fit.
- Fastig, we can't afford new slicks (these were bought from Michelin New Zealand second hand) they had done a 12 lap test with them when we bought them. But will definitely get pyrometer
    • You're probably right about that one. Thanks for your suggestions, I hope I don't need a new 3rd brake light. Although wiring issues might arguably be worse. Right now I'm in the midst of a turbo removal because of my oil leak, other problems are going to have to wait for now.
    • Hell, I know that much. So far I just put it off as "part of the deal".
    • I removed the head expecting to find broken and bent valves, but instead found number 1 at TDC and cylinder 2 at the top of its cylinder stroke as well, thought that was weird and proceeded to push cylinder 2 back down until it either bottomed out on its other piston half or the conrod either way we found the issue kind of,  now to remove the engine and see how the block looks, hopefully its just the top off a piston.
    • A little more work this week.  Fitted astra power steering pump in the boot with a lowe fabrication bracket. Gave the pump a good clean, fitted Anderson plug and high pressure fitting. With the intercooler being flipped under rad support factory headlights weren't going to work. Ordered a set of origin battle lights, they arrived so got them test fitted. Will require some fiddling to fit nice but was an easy quick option for now. And today we pulled out the manual Rb gearbox and test fitted a ZF 8HP50. It will fit with some casting tabs cut off and small tap of the tunnel with a hammer. Pick up the adapter plate Wednesday so hopefully all bolted in Friday and measure for tailshaft which will be a 2 piece. Been doing a lot of ecu, pdm and tcu loom design so when comes to wiring it in a few weeks will all go smoothly.
