http://www.skylinesaustralia.com/forums/topic/388872-drag-dates-2012-so-far/
think you will find most entries are full allready.
Martin at this stage it will never get to full 1/4 again as not enough run off any more for ANDRA to be happy with. when the top fuelers come later they are only running 1000ft.
FYI
Hi guys, I have 10 positions available for racing next weekend being 12th February 2012 due to non payers, cars not ready and forms not being returned. If you would like to enter, please give me a call on 0419722464.
There will be no entries available on race day so please do not rock up race day and assume you can race. Lets feel these spots and make it a sell out event again and one hell of a "Morpowa Super Sunday"
Regards
Rino
If thats true, how come Rino himself said it will go 1/4 mile?
^^ im trying to find the comment he made regarding why it wont be full 1/4 anymore. the run off area is not long enough any more to comply with new ANDRA rules for top fullers as the cars have got faster but run off hasnt, it also has something to do with the house across the road which is directly inline with the run off area being to close now.
that being said maybe street drags etc (all except top fuelers and doorslamers may run the full 1/4 in time if they get ANDRA approval.
Racing Onn Promotions: Martin, unfortunatley we are not able to run group 1 at 1/4 mile, the cars are getting faster but the track not getting longer. Top Fuel, Alcohol, Pro and Top Bike in April will run 1000ft. (that is from his facebook)
Judging by Rino's comments on his FB page it appears the plan is to run off-street 1/4-mile events in the future when additional concrete barriers become available to complete the RHS track safety barrier - I noticed a comment stating the additional barriers required are currently set aside for use at the Clipsal 500.
"Racing Onn Promotions Hi, it will be 1/8th mile again for reasons beyond our control, we are not able to secure the Clipsal 500 walling until after Clipsal..."
The venue as it currently stands (plus completion of all safety barriers) will never see a return to ANDRA Group 1 1/4-mile racing due to the lack of run-off and no room for expansion. A lack of Group 1 racing over the 1/4-mile doesn't automatically mean no 1/4-mile of any kind... so fingers crossed.
The ANDRA Group 1 meeting 13-15 Apr will run over 1000ft (304m).
^^^haha from what i gather is cars for this meeting still 660ft (barriers being used for clipsal) when they come back it will be full 1/4 for cars but yes 1000ft for top fuellers etc.
not sure if that means that between 1000ft and the 1/4 that the track will be re surfaced there or not.
Clispal is in March, barriers not available till well after Clipsal therefore no barriers for AIR till end of March limiting drag events to 660ft. ANDRA Group 1 meet is in April, April comes after March... which means the barriers required will be available by the Group 1 event. Seemed obvious enough to me :D
  • 1 month later...
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
    • 300hp (225kw) is barely outside the standard turbo's range with a bit of extra boost in it (200ish). If you are going to change the turbo you should aim for 250-300kw (330-400hp) to make the expense worthwhile
    • A couple of things, firstly omg that turbo is expensive! $3,000 USD for dinosaur technology is robbery. You could buy a G series turbo and have a good amount of change instead.  If you want a good budget option, have a look here - https://hypergearturbos.com/product/rb25dethighflow/ If you are keen to spend more, have look at the modern turbos, Garrett G series, Borgwarner EFR, etc. Have a look at the RB25 dyno results thread for inspiration.  If you upgrade your turbo to something that will support the 300hp you want and only "probably" have Haltech ECU, your car will only "probably" run. Actually, no it won't run. You are going to need the ECU and injectors at the time you do the turbo upgrade.  No thoughts on "this much boost" as you didn't say how much boost that actually is. Having said that, plenty of unopened RB25's making even more power then what you are chasing.
