It's on like Donkey Kong!
On Sunday the 26th we will be holding a social based SAU cruise leaving from Perth and heading out for a decent run and stopping in York for Lunch. Now remember this is not a race (unless your name is Paul... :whistling:) but more of a fun cruise with a bunch of (reasonably) nice people from around and about SAUWA.
Departing: Midland Gate Shopping Centre. We will try and assemble at the undercover car park facing Great Eastern Hwy.
Time: Meet at 10:00am for a projected 10:30am departure.
Date: Sunday February 26
Bring: Money for lunch (or something packed to eat), plenty of fuel and your big boy pants as this is not a small map.
Whether you drive an early model Datsun, a Nazi Sled or an HKS tuned R35 GT-R all are welcome. Hope to see you there.
:cheers:
*Stay tuned for possible changes.
Dudley and I will be there with bells on!
so please contain your hillarity in the presence of the easily offended kthnx
Remind me closer to the date?
Cruising in an NA is going to be embarrassing. :(
Lol
Clearly you have no idea what Dale and myself will be captaining...
(You'll be more then fine in an NA mate, come along!)
... and I didn't make you buy Hitler's car.... :whistling:
If i recall correctly he drove in merc's. He funded and push VW as the everypersons car (well his everyperson)
Im NA so you will fit in no prob, hell i dont even have a skyline!
Lol
No Cossie?
You aryan sunamagun!
No Cossie?
I wouldn't put money on it mate, but anything is possible! Most likely roll in ze Celica!
No Cossie?
R32 golf?
been wanting to 'compare notes', i had to make the decision in purchase...
R32 golf?
i kept up (with out really trying) with a m's z4 the other week utill he started speeding. dont think he liked the fact i stuck onto his ass and woundnt go away.
Z4MC, or mates Z4?
traction comes in handy... my old 32GTST was useless until 80km/h +
and yes, the factory exhaust on the R32 gold sounds better :P
A M speed (or what ever its called, has the M badge on the back) one i have no mates..........................with a BMU!
Dale (Stinkyrooster) came for a ride on the weekend and loved the note out of the stock exhaust.
he mentioned.
people put M badges on everything these days, or there are m sport packs :P
A real Z4MC has the M3 engine etc.
I will bring a wading pool full of jelly and a couple of sequined mankinis in the back of the ute, so you two V2 pilots can hug it out, k?
Come to think of it, when did this cruise become all about reprezenting the losing sides of WW2?
isnt your car german?(not the 1200) :P
he mentioned.
*shruggs*
Saw the badge, it sounded nice and the guy looked like a tosser so i thought it was the full monty. once he started speeding it did take off quite fast. dont know.
mmm tub full of jelly
jlghdriog'erijyh'oeiAJRgh'J
*wipes drool off keybored*
sometime's the losers are winners...............................
    • Does it make a difference in your turbo having a shorter life if you have a cat converter as it causes that back pressure versus less/no back pressure with a decat? (Not sure if this is accurate) Also slightly different question if you went from a oem cat to a decat or vice versa will it require a tune? I heard if you change the dump pipe onwards it requires a tune?
    • No. Have only gotten as far as contemplating the task of having to put in the required fairly heavy wiring and fusing to run it (along with the big alternator), and preferring not to. But otherwise, it would be nice to have a little extra freedom as to exactly where the compressor is located and free up some space around the exhaust side of the engine.
    • Following from this in a related by not closely-related sense... Because I was buying a bunch of other GKTech stuff, I got some rear subframe collars. The history that leads up to this is: 25+ years ago the car arrived into the country with stock subframe bushes. At some point shortly thereafter I added Whiteline pineapple rings, set up neutral, and it improved the rear end behaviour. Well, it is my vague memory that I was happier with it with them in. Less axle tramp on launches, generally better, etc etc. ~2012 it got a new non-HICAS subframe with new stock bushes. No pineapple rings. I reckon that ever since then I've been dissatisfied with the axle tramp. Recently I've been f**king around a lot with all aspects of the suspension. One contemplation has been to relocate the rear lower control arm front mount points (and do the other things needed to make that work) to improve longitudinal rear grip by getting rid of some of the stupid anti-squat that Nissan ladled into the R32. But.... before doing that I thought I'd put some collars in. And.... The collars are good. The rear sounds a little bit different, but there has been no significant increase in NVH coming up into the body. In terms of rear behaviour - expansion joints on long sweeping elevated freeway ramps that would sometimes cause the rear to jiggle around a bit, no longer seem to do so. It appears that jamming chunks of metal into the gaps in the rubber so they can't move much is a really good thing. And the launch behaviour and general forward traction situation seems to be greatly improved too. It's impossible to be really sure, because the tyres are completely shagged - they are freakishly willing to let go right now. But as an A-B test with the same tyres it certainly seems to grip up a lot better. Highly recommended to anyone who still has stock bushes.
    • Bit off topic maybe but has anyone had a crack at one of those aftermarket electric compressors ? Bit of a search came up with one put out by Speedy Air Spares. Looks interesting and looks as if you'd have to run a big arse alternator. Found this out after the fact as my air con compressor packed it in and soon after my alternator ! !
    • Yes. Needs new ports. Usually just achieved by screwing an adapter onto them. Be aware that any AC compressor that hasn't been used in a long time will very likely have dried out seals and will not hold gas. Oh, and obviously you will require a new receiver-dryer also.
