For the FWD ones? I'd imagine thats not the price for the eccentric ones - if it is gimme!
Neither of those names line up to the SuperPro catalogue Dale and Paul - is it Strut Bar To Chassis Mount Kit - SPF2849K or Control Arm Lower-Inner Bushing - SPF3298K?
https://www.sau.com.au/forums/topic/390177-torn-bush-m35/#findComment-6214374
It's the "strut bar to chassis mount kit"
It's job is to stop the forward/backward movement of the lower control arm, essentially, castor. So thats what I call it as most people know this by that name and it can adjust castor with offset bushes or an adjustable arm. No other arm up front can adjust castor.
https://www.sau.com.au/forums/topic/390177-torn-bush-m35/#findComment-6214406
Jay might be talking about OEM bushes? That's about what I saw when looking on ebay.
I understand what it does, but Nissan made the arm, and they refer to the arm as a compression rod, and the bush as a compression rod bush.
The bush manufacturers can call it a piano if they want, doesn't make it so.
https://www.sau.com.au/forums/topic/390177-torn-bush-m35/#findComment-6214450
SuperPro told me they don't make piano's for M35s. Shit out of luck. That would make sense about OEM bushes though.
Thanks Paul, they do make strut bar to chassis mount kits. That we can do :thumbsup:
Were you wanting on on the GB too Paul, or did you find another source for your kit?
https://www.sau.com.au/forums/topic/390177-torn-bush-m35/#findComment-6214473
From this day forth it shall be known as piano.
Sorry Dale, I call BS. Can't find this "piano" for my M35 ANYWHERE.
:pwned: Lol, cheers guys.pinch.gif I'll stop "helping' now...
Did anyone else notice sav man's AXIS is LHD?:whistling:
Edited by Daleo
https://www.sau.com.au/forums/topic/390177-torn-bush-m35/#findComment-6214742
lol.......It actually looks like a G35!....no front shaft....different shocks. Shows us the part he needs though.
https://www.sau.com.au/forums/topic/390177-torn-bush-m35/#findComment-6214754
Lol, I was puzzled at first because the compression rod; sorry PIANO:nyaanyaa: in the pic looked brand new. Realised after that it was just a googled image...
Going OK :ph34r: , Jigs are made, just have to source some material. Work is slowing me down on that front ATM. Have you got time for my pianos this week, or next week?
https://www.sau.com.au/forums/topic/390177-torn-bush-m35/#findComment-6214766
yup........I'll give you a call as soon as I get other things sorted though.
https://www.sau.com.au/forums/topic/390177-torn-bush-m35/#findComment-6214858
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
