As per the title above. Does anyone know where I can get some second hand or new struts to stop my boot and bonnet falling down??
Global Warmer, where are you situated?
Try these guys; http://www.strutregas.com.au/ Cost is roughly $80 per pair, from memory. They provide a 12 month warranty as well.
I've used them 4 times with different cars, and they've all lasted the rest of the time I've owned the car.:thumbsup: One was more than 6 years.
Unless the strut is completely rooted (and they'll tell you) you'd be better off re-gassing your OEM struts than using second hand ones which will likely do the same thing.
Cheers, Dale.
Cheers, Dale.
Thanks Mate!~I am in Singleton in the hunter valley at the end of Putty road nyaanyaa.gif.
Nice know it well, many a Putty run on my GSXR1000...:whistling:
This is the "Hunter Region" Rep; Even though Wickham is farkin' miles away... Still, they say they'll come to you.
Strut Re-gas Hunter
Arie Oosterveen
Cnr Church & Foundry St
Wickam NSW 2293
Ph: 02 4961 3255
Good luck, Dale.
I neede new struts for my Toyota - went to the wreckers and they were very honest - said 2nd hand ones are all droopy - so I rang the mobile regas and they fitted new generic ones for about $70 a pair.
    • But if you've got the flex sensor whats the issue? You just run what you can get your hands on.  I can't see any reason not to run e85 if it's relatively local to where you live.
    • Exhaust end of this month, and then tune after that whenever there is availability. Still tossing up between a pure 98 tune or a flex 98/e85 combo.  The (lack of) milage in e85 isnt great. Start to get anxiety if i go for a long drive and there arent any united servo's nearby
    • I mean I can be OCD'y but this is really over the top. At that point why not just run a full wideband fuel controller? Especially if you run 3 widebands. The system works pretty well, which is trimming low load stuff to be within a few percent of the base map. Pre-engine _change_ the base map was only 1-2% off, depending on ambient temp, elevation, etc. Under load the LS is really very straightforward to tune, enough that a wideband closed loop would be overkill. If I really cared (and I hope I don't) I can always just go back to the MAF system the car actually came with. Which does all those nice calculations for me (temp, altitude, etc), now that you can buy 102mm MAF's that do not cause restrictions.
    • Good afternoon Team , just a quick update on performance mods  Current Mods list (Installed) HKS - Power Editor (Came with the car) looks to be some kind of boost controller RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Cat Back  RV37 Skyline 400R (SKYLINE) | FUJITSUBO  - Front Pipe AMS  - INFINITI Q50/Q60 RED ALPHA COLD AIR INTAKE KIT AMS  - Performance Heat Exchanger Intercooler Not Yet AMS Alpha Performance Full Race Down Pipes  - to be installed in May
    • I'd be installing 2x widebands and using the NB simulation outputs to the ECU.
