Right now, i'm interested in the High stands, spoiler blade and exhaust shroud.
Hopefully can spread the word and bring those prices down.
so you dont want the wind deflectors anymore?
and is the exhaust shroud to suit R34 or R33 GTR rear bar
  • Replies 221
Posted Images
JD32R, i checked the thread that you posted up about the wind deflectors you purchased and it is not the same seller.
http://www.skylinesaustralia.com/forums/topic/368821-r32-carbon-fibre-wind-deflectors/
UPDATE list of interest
AAARGH 33 - R33 B pillar cover & fuse box cover
75coupe - R33 B pillar cover, fuse box cover, r33 gtr rear spoiler end caps, r33 gtr oem wing blade
sonnyQ - r34 gtt radiator cooling panel
GT-T 1998 - r34 gtt radiator cooling panel
Owgasm - R34 GTR wing blade, r34 gtr jun style wing stands
rysith - R34 gtr exhaust shroud
dori34 - R34 gtt/gtr wind deflectors, r34 gtt cooling panel, r34 gtr exhaust shroud
gtsttrk - R33 fuse box cover
eatme - r33 gtr wing blade
destrukshun - R34 gtt/gtr wind deflectors, R34 GTR oem exhaust shroud
vspecIInur - R34 gtr Jun style wing stands
pewpew - r34 gtr wing blade
With the carbon wing blade.
Is it just the blade like the knight racer one and nismo one where you use your own end caps. Or is it carbon end caps (as ll the ones I have seen with carbon end caps buldge out of the wing 5-10mm and doesnt look like a nice fitment)
Do you have pics of the wing blade and the wing blade fitted.
Thanks
Edited by sinistaGTR
Updated list of interest
ztuned - R34 gtr wing blade
tommyr34 - R34 GTR wing blade
MsR - R33 GTR exhaust shroud
im up for an exhaust shroud for 33 :) interested in the headlight intake too but how good is the fitment? is it only a single entry as per the pic you showed on pg1?
single entry only, manufacturer claims fitment to be as close to OEM as possible however i've seen track cars with similar headlight intakes from Japan and fitment was not 100%.
i will need 2 ppl to order the headlight for it to go ahead
also can u get the twin and /or gauge holder which mounts on the dash? im afger a dash moubt triple and a twin which sits ontop where the cluster area is
nothing like this.
Assuming the 32 wind deflectors are for a coupe and not sedan?
Will be interested if they are for a 4 door.
Cheers
sorry i shouldve stated, they are for 2 door coupe only.
interested in R32 GTR carbon headlight intake
please see the above comments to MSR's question, if you're okay with this, i'll add you to the list (but i will need to confirm pricing on the headlight for R32 but it should be similarly priced to the R33/R34 GTR ones) i will need 2 ppl to order the headlight for it to go ahead
here is a pic of that the manufacturer sent to me
Update price list
R33 B pillar cover x2 $75
R33 fuse box cover x3 $80
R33 rear spoiler end caps $45
R33 GTR OEM wing blade x2 $140
R33 GTR headlight intake $140
R34 radiator cooling panel x3 $80
R34 GTR JUN style wing stands x2 $140
R33 wind deflectors $95
R34 wind deflectors x2 $95
R34 GTR exhaust shroud x2 $55
R33 GTR exhaust shroud x2 $55
R34 GTR passenger headlight intake $140
R34 GTR OEM spoiler blade x4 $130
1-3 current pricing
4-7 current pricing minus $10
7+ current pricing minus $20
please note that i will need at least 2 ppl for each item for it to go ahead, otherwise unfortunately they may miss out unless i can negotiate something with the manufacturer for a single order.
interest so far has been good guys, if all who has shown interest now and is on the updated list a few posts up, this group buy is going ahead :woot:
Sweet :)
Don't close it yet.
Give it a bit of time for people to see. :)
its not closing until the 24th. but i will be sending everyone a PM next Friday to start accepting 50% payments so i can get this underway due to the long production and shipping times.
Not sure if it is something you have thought about but customs will have a field day if you order all of that stuff in one go, regardless if they do you up a fake invoice under $1000.
Will suddenly blow the prices out something fierce.
Food for thought.
Thanks
sorry mate, didn't see your post.
pretty sure its just a oem rear blade replacement and you reuse your own end caps as manufacturer didn't mention anything about end caps.
i will try and get a photo.
ATT: R34 owners, would anyone be interested in the mines bootlid spoiler?
depending on how good this group buy goes, i may organise to have my FRP one sent off to get replicated in CF.
    • Ye, in terms of bolting up the "Conversion" from a GT to a GTT is effectively "Use GTT parts for everything" Except the subframe itself, because you won't want a HICAS/4WS subframe. Remember your ABS system will be different too, thanks to GT being the S15 3 sensor system, instead of the R34 4 sensor system for wheel speed. I do not know how people get this to work given R34 diffs do not have a provision for an ABS sensor (they are on the tone wheels of the axles). I assume***** people use S15 gear/R34NA forever when they realize this - Or they convert it to a rear diff/axles that are R33 style which I presume has the singular speed sensor on the diff itself, but then you have to wire it all in and...and... and...
    • Foreshadowing was never so easy.
    • The ones in brackets are the first stages of tightening. I usually aim for the middle of the range. They give a range because it's actually not that critical to hit exactly the right bolt tension. Enough is enough, and too much is too much, and the range given is inside that range. Half of the bolts in the suspension are problematic for putting a torque wrench on anyway, so just get done up to mechanic tight  and spanner checked a week later.
    • Is the problem that we just disconnected the line, does it need to be plugged? I’d rather not buy another master cylinder
    • Clutch is same same. Tailshaft is not. Diff will drop in. Half-shafts will not mate up (5x1 on turbo, 3x2 on NA). There is also the strong possibility that your auto NA gets its speed signal from the sensor on the diff, not the gearbag, and that will leave you without a speedo. You can do all this, you just have to do a lot more than you thought.
