$90 if you want to keep it + postage.
measurements below:
Carbon wing blade : 130.8cm
Original OEM blade with end plates: 131.3cm
Original OEM blade without end plates: 130.3cm
End Plates: 5mm each
so they are approximately 5mm shorter/longer with/without end plates.
Cheers
  • Replies 221
Posted Images
Just wanting to know if we are to keep the carbon blade what's needed for it to fit right? And also alot of us do track days if we're going around at 180 is there a chance that because it's not properly fitted that it could some how come lose and fly off?
no headlight intake for R33 S2.
GTR only i think it had (need to double check)
Owgasm, most likely 2mm alloy is best. I will have it drawn up in CAD for you guys to send around to get quotes on.
Tommyr34, it will not fall off as its still held in by the same amount of screws as OEM.
If everyone is happy to pay $90 for the wing blade (just waiting on ztuned & tommyR34) to confirm, let me know ASAP via PM.
Owgasm & sinistaGTR, will let you know when the refund goes through.
PewPew, let me know of yours and ztuned's final decision asap :)
Thanks all and sorry about all this hassle.
Ive installed some of my CF parts from this group buy, thought everyone might like to see some results.
I do still need to remove all the parts and get them clear coated to stop them going milky.
that includes removing my PSI parts fog light covers cause one of those has gone milky already and the car is pretty much always in the garage, I hardly get a chance to drive it. I still also have a rear diffuser and eye lids both in CF to install too, Im hoping all the different brands of parts have very similar or matching weaves and colours.
The OEM wing blade wasnt easy to get off for starters, an end bolt needed to be drilled out as it was free turning, but after coming to the dreaded decision that must be done it wasnt too bad and the OEM wing will live to be installed again if needed.
the CF wing blade and end caps fitted not too bad considering the price to be honest...
some slight modifications to the mounting points and some widening of the bolt holes in the blade bracket on the car and they were a firm fit
from the front post-26316-0-58053800-1339391608_thumb.jpg overall post-26316-0-55410800-1339391613_thumb.jpg from the front the frontpost-26316-0-03208700-1339391607_thumb.jpg
from the top on the right post-26316-0-23433900-1339391610_thumb.jpg End cap post-26316-0-44847400-1339391611_thumb.jpg
The fuse box cover wasnt an easy OEM fit either but some mild persuasion and it was all good.
In comparison to other more expensive CF parts there are obvious fitting differences, the most expensive parts fit perfect like OEM, but to the untrained eye most would not be able to tell the differences between these parts from the group buy to the brand name jap stuff I have.
I did a weave shot from my Garage Defend cooling panel and the fuse box cover. there is a slight wave in the surface of the fuse box cover and the weave is bit neater on the defend piece but overall similar size weave on both so may come fairly close to matching.
oh I do have Bpillars from this group buy to install as well but I got sent two left hand side ones so Dori is fixing that up for me...
pics of it installed will come along once the part is here.
ive had carbon parts on my car for years now, it was parked out in the sunlight everday at work for 4 years and i have never had any of my parts fade or go milky as you put it, have never had any special coat put on them n they are from alot of different suppliers.
i honsetly dont see how people are having so much trouble with parts fadding
It is interesting to note that only one of the fog light covers has gone milky, the other is fine, so thats even stranger cause same supplier, same batch even, same sunlight exposure... so I dunno...
thanks for the pics Scott!
i love the carbon blade on the R33 cause its much thicker than the R34, it makes the car stand out!
i have 2 R34 wing blades left over, for $90 each, does anyone want to purchase them?
This is the CAD drawing for the R34 end plates, you can run these as optional, i recommend just getting the basic shape of the plate, and get bolts to suit and the holes drilled and tapered to suit the bolt, recommended plate thickness = 2mm.
2.5mm end plate may fit as well.
The standard screws will not fit as they are too fat and wide.
so some hunting around for 2mm thick tappered head screws (like below) or ultra flat pan screws.
Carbon wing blade without end plates: 130.8cm
Carbon wing blade with 2mm alloy end plates: 131.2cm
  • 3 weeks later...
Guest
    • I have engineer in my job title One of or motto's though is "we make and we break"
    • This is actually 2 whole different trains of thought that need to be addressed separately. No, as Matt says above, "Engineer" is not a directly protected title. A lot of guys who just do mechanical design via CAD, with or without even some sort of associate diploma in engineering, often have the job title of "Design Engineer". A train driver can probably still describe themselves as an engineer. But, to usefully get employment with anyone as a proper engineer, you're going to have to have at least the necessary and relevant degree qualification. You're not going to get a job as an electrical engineer if you have a chem eng degree, unless you can demonstrate x number of years of working in that capacity, sufficient knowledge, etc. Having the degree is at least in indication that you've seen the relevant text books, even if you haven't read them (like pretty much the last 10 years of graduates!). To be a self employed engineer.....you could get away with quite a lot pretending that you're suitably qualified, without actually being a proper engineer. But, you will find yourself unable to work for a large section of the client space because a lot demand CVs and capability statements when considering contracting for any engineering work these days. Insurances too. If you're not a proper engineer, it will be much harder to obtain proper PI insurance. Insurance companies have gotten hip to that. The "Professional Engineer" thing is a thing in Australia. If you have the right qualifications and experience you can apply to the relevant engineering top level body (mostly Engineers Australia, the less said about whom, the better), to be assessed and approved as a Chartered Professional Engineer, CPE. There are high bars to get over and a requirement for CPD to maintain it. The RPEQ thing is similar-ish, in that you have to demonstrate and maintain, but the bars are a little lower. It is required to be RPEQ in order to sign off as an engineer on any engineering design in Queensland. The other states haven't fully followed suit yet. There's "engineering" and there's "engineering". Being an engineer that signs off on timber (or even steel) frames for housing projects, council creek crossing bridges, etc, is a flavour of civil engineering that barely warrants the name, description and degree. That would be soul crushing work anyway. Being an automotive engineer working in the space where you have to sign off on modifications to cars and trucks would also be similarly soul crushing. At least partly because of the level of clientelle, their expecations, depths of bank balance, etc. And that brings us to your second question. No, we do not have professional engineers "do vehicle inspections". Well, not the regular roadworthies, etc etc. That's done by mechanics. There might be some vehicle standards engineers at the various state govco inspection stations where cars go to get defects cleared and so on, but that's because they (the cars) are there specifically for defect inspection and clearance and so the stakes are a little higher than on an annual lights and brakes working check. But, if you modify a vehicle in Australia, you have to get it engineered. A suitably qualified (and effectively licensed, which I will get back to) automotive engineer will have to go over the application, advise on what would be required to make the mods legal, supervise some parts of the work, inspect and test the results, and sign off. The "licensed" aspect comes from there being a list of approved engineers to do these things in each state. They have to jump through hoops set up by the govco vehicle standards divisions that mean only the suitably qualified can offer to and approve such mods.
    • It's got a problem Prank... It looks like both washer spray caps have fallen off this car... 😛
    • Meh, it's only got to last another 10 years or so until you'll be forbidden to drive it. Keep it dry and forget about it.
    • The title of Engineer is not protected. However different states have different rules about what an Engineer requires to operate. Engineering for a motor vehicle modification is very different to engineering for a bridge, electronics, etc, including what that engineer needs as certifications.   In Canberra, "Engineer" is the loosest category with basically nothing stopping you calling yourself and engineer and designing a bridge or building. From what I've reviewed, QLD has the strictest requirements through RPEIQ.
