Hey all.
Was reading a import mag earlier with a silver cefiro owned by a fella in victoria called chris, seen he relocated his under bonnet fuse box.
And I wanna do the same, just wondering where would be the best place, I was thinking maybe glove box. Boots too far but would be the go.
And noo im not putting a cover over it. :P
Cheers
Choc
https://www.sau.com.au/forums/topic/390272-relocating-fusebox-in-cefiro/
if youre going to do it, do it properly, pull the dash out, pull the whole loom out ect
i did it with dash in and didnt remove the loom, was nothing but drama's, shit not working, stuff shorting out, blowing fuses, massive mess under the dash
i ended up starting again with a new loom and left it in the stock spot and just stripped it to bare minimum
this is what i ripped out
started again with a fresh loom
stripped off everything i didnt need and put it all back in
Edited by Kris..
I've just done mine chocky. basically pull the full loom from out of the front of the car. Strip the tape off the loom and work out where its going to sit under the dash, mine is right next to the other fuse panel cable tied up out of the way. Then cut and shorten and solder/heatshrink each cable one by one. while the loom was stripped I also removed the Abs wiring to cut out some cables, then I also drilled a hole just above the chassis rail near the alternator to bring that wiring out under the guard then back over the wheel arch and moved the battery to the boot but run the power wire in behind the strut down under the break booster to the starter motor. Having it ran here also allowed me to put a decent fuse in and also a place to put the jumper leads if i need to jump start the car again.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.
    • I've always approached this as, price is comparable between low temp and high temp fluid. Just put in the high temp fluid. I've not going to lose any sleep thinking about could I have saved $20 on brake fluid that is going to live in the car over the next 2 to 3 years.
    • Nah, the creases were pretty large, and the sheet metal is pretty thin and hard to work out, time alone is in the hours to fix, and would probably have more bog than I would be happy with In other, more happy news, I gave MX5 Mania a call and they have a few clean boots available for $400 a peice, I've contacted Fineline and given them their contact details, I'm a idiot for not thinking of them sooner
    • That really depends on how hot the brakes get and how much of any heat is transferred into the fluid. That really makes it at least a vehicle specific question, and more than like a specific vehicle specific question, depending on what brakes (ie stock, bigger rotors, different calipers) or even what pads are on it. And then there's the question of cooling air. Is there plenty stock? Is there no special cooling arrangements stock? Has some/more been added? In other words, I think you have to do the experiment to obtain the data. And if you;re worried - tie on some ducting?
    • In all the track days I've done over the past few months I've only had 1 issue with braking and thats with my current EBC pads (can't remember the colour, but they're not a track pad). I don't *think* I have had issues with brake fluid getting too hot, my understanding is that when that happens you will have quite noticeable brake loss - which I haven't had.  I'm using just regular ol' Penrite Super DOT4 fluid. I use this fluid in everything and my cars always seem to stop so I see no reason to change, except ... for the 335i. I need to do a fluid flush and was thinking about my fluid of choice and wondering if I should consider using something more high temp? Its not a super fast car by any standards but I'd hate to do a flush and then find myself with no brakes when I get. to Wakefield.  I guess, my question can be summed up as "How fast do you need to be driving to need higher temp brake fluid?"  I remember high temp fluid was considered a must have back in the day when I had my GTR.
