Looking to replace the original radiator on my r32 but i'm not sure if radiator thickness or number of cores/rows makes a difference? Been looking on ebay and other part's sites and i've seen all different kinds like 40mm 42mm 50mm 57mm, not sure which to go for as i just want to replace the old one without having to make any other mods etc. Any help is appreciated Cheers
https://www.sau.com.au/forums/topic/390276-does-radiator-thickness-matter/
Thicker core == larger body of water + more surface area.
This pretty much just means that you can provide more cooling capabilities.
Unless you plan on pushing some serious horsies out from your engine you shouldn't need much more than stock core size (though with Aus weather, a little bit extra wouldn't hurt).
Be careful of the fit if you go non-standard size - you don't want the fan taking a bite out of the shroud... Some of the ebay ones dont fit at all.... You should be able to find an SAU trader with something to suit, and that would be a safer bet.
I run one of these Fenix 42mm radiators in my R33. Fits fine with factory fan shroud!
40 or 42 mm is the way to go as that will allow you to run the standard fan shroud and not have any clearance problems.
If you run any larger then you can have clearance problems and also your motor can run too cold if it is in close to stock condition. I run a 40 mm core with about 230kw and have difficulty getting the car up to normal operating temps even at track days and at Sydney Drags.
This is true!
Last time my car saw "normal" water temps was at Wakefield in December!
I have a brand new alloy radiator i think is for an r32 i have a 33 and only realised a year later when trying to fit. ill try find out. its about 40mm thick. pm me if your interested
Edited by abr33
But if u have a properly working thermosat it should self regulate the temps regardless of the radiator temps??
Brand new radiator, brand new thermostat. Factory temp sensor never goes over 70degC on the street
Is it worth it for a car pushing about 260rwkw? During the cooler days my average temps are 76 - 83C. On hot days I can see it rise up to about 88 - 89c on the power FC. I don't even need to be giving it a hard time. No idea if this is a concern or not...
No concern. It's perfectly fine operating temperatures.
I have a 52mm radiator in my R33 and it fits with the factory shroud and clutch fan, so you can definitely get away with that size too. Been running it for a month or so now with no issues.
Agreed that Its perfectly normal to be into the 90's. Most modern cars run alot hotter than older ones anyway due to emissions so its not going to hurt. R34's run in the 90's stock. Thermostat starts opening at 84C i believe, fully open at 95. Whereas R33's open at 72C, fully open at 85C.
My OEM Nissan thermostat used to have the car sit at around 84-85C cruising the streets and highways. I replaced it with a higher flowing unit as i was getting a tad hot on the track. The aftermarked thermostat opens slightly hotter than OEM, be it 3C i believe. And now cruises at about 88C. It cools far better than the stock one though. I actually see a temperature drop when i give it a bootful lol. 300rwkw,
  • 1 month later...
I just thought some more about this- It aint right. Unless you are living in a very low temp area (snow areas) and have a low temp thermostat...
An OEM R33 thermostat doesnt start opening until the 70's so there is no way the water in the motor could stay that cold without flowing thru the radiator, and a very cold radiator at that...
Yep agree with that. Starts opening at 72/73C and fully open by 85.
And also, VCT doesnt even start working till ECT is above 75C.
Nismo low temp thermostat, live in Sydney
I'm not saying it's right, just what ECUtalk reports ;)
    • Update: I got the magnet out. I bought 3 different flexible magnetic reach tools, but none of them worked. The magnet on the tip was all less than 2lbs of force, so i had to buy a special cylindrical magnet that had a pull force of 9lbs.  The magnet finally came in the mail yesterday, so i got under the car to get to work. The super strong magnet isn't that long, so i only have about 1 finger pinch lengths to hold it. I was so scared when i was going in the hole, that the 9lb magnet would just fly away inside the oil pan never to be seen again, but i had my butt cheeks clenched and finger gripped on that thing so tight, i managed to get it to suck the other magnet out.  It was a victory for me last night.
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
