Yuh, but if you have to pay anything for it, you are being ripped off.
Both N2 and O2 are as near as damnit ideal gases. Together they make up more than 99% of typical air. The majority of the remainder is water vapour, which is less of an ideal gas. The difference in behaviour between air filled tyres and N2 filled tyres is really small. Justified in racing classes or in supercars perhaps, but hardly justified in normal cars - even super duper hot wheels brrrrm brrrm vrrmpsh like Skylines.
Nitrogen has a lower coefficient of expansion than air, so the pressure inside the tyre doesn't change as much as it heats and cools. SFA difference on the street. On the track i guess it means you can start cold with a little more pressure, so your cold tyres aren't as mushy as they come up to temp.
If you do put it in and you're somewhat disappointed at the result, try sitting on the ground with your legs either side of the tyre and push the valve right in: you might get a laugh out of it :)
lol wut?
Can't hurt, it just means you get less affected by changes in tire heat
not tru
during many race seasons i had a driver who insisted on nitrogen. so we abliged, the pressure change was markedly higher than air from a compressor.
the ONLY advantage is being able to have repeatable results. having the same air in the tyre each race. it alows for a quicker set up being able to predict a pressure for a given tyre temp. humidity is the factor with normal compressed air. since the atmosphere is 78% nitrogen anyway.
but the fact remains the pressure would raise more with n2.
if anyone has some hard data to sugest otherwise. ie: go out 30 psi with a ambiant tyre temp and come in with 30 psi with a 90 deg c tyre i will donate a leg..
n2 in a road car is the biggest WANK ever. and a complete waste of time. and the n2 has to be from a bottle. and to remove any moisture from the air in the tyre already is imposible. mayby if it was filled and deflated and vacumed 100 times you might get 100%n2 in there.
    • The water pump is know to leak as well. So if the coolant is low checking that first as well as hoses.
    • Reading your posts Josh, sometimes I feel like I've gone in a time machine back to the 90's when everyone was doe-eyed and figuring things out for the first time.  I've lost track of how many single turbo GTR's I've seen on track that haven't burnt down lol. Everything has been figured out a long time ago. These things are at the point now where its essentially turn-key to go single turbo.
    • Among other things yes. Making sure to either use an oil pressure regulator or the right restrictor size for your oil pump/range of oil viscosities you intend to run, making sure you plumb the lines correctly, turbo should be placed such that it siphons properly even when the water pump isn't turning so you don't boil coolant in the turbo after shutdown, oil return should be low resistance and also preferably picking the one that is most likely to return to the pickup as opposed to some other irrelevant part of the pan. It's far from impossible to figure this out but I have seen people really, really struggle and if that's the case it's easier to just take the path of least resistance. To me, bolt-on twin turbos are a fixed cost whereas single turbo is almost unbounded.
    • Latest round of updates on the car. I purchased and installed a SWS clutch slipper to help with 60ft times and got some second-hand good condition 275/40R17 Hoosier DR2 radials. Test and tune in November showed the tyres were an upgrade over my over 15 year old mickey Thompson's and I got a 1.8 second 60ft and pb et of 11.71 but even then, that run wasn't great due to rain and driver error (the event got called off 10 minutes later fast forward to the weekend just gone 25th of Jan and there was finally a break in the weather to let racing happen. The first run the track was slippery and only managed a 12.1@129 Second run the track was better and got a new pb et and mph: 11.54@131   Lith and I then worked out that I installed the previously mentioned clutch slipper incorrectly and its never been working, and I had just been dumping the clutch the entire time, we also noticed it was on street boost and not race boost. So I lined up for a third run with the car turned up in the first two gears, but the passengers side axle objected to clutch dumps and left the chat which stopped my weekend.   so there will be another attempt in the future once I replace the tyres as they rubbed and are stuffed now. but a low 11 should be on the cards.
    • Ceramic coating and heat shielding, you mean?
