Yuh, but if you have to pay anything for it, you are being ripped off.
Both N2 and O2 are as near as damnit ideal gases. Together they make up more than 99% of typical air. The majority of the remainder is water vapour, which is less of an ideal gas. The difference in behaviour between air filled tyres and N2 filled tyres is really small. Justified in racing classes or in supercars perhaps, but hardly justified in normal cars - even super duper hot wheels brrrrm brrrm vrrmpsh like Skylines.
Nitrogen has a lower coefficient of expansion than air, so the pressure inside the tyre doesn't change as much as it heats and cools. SFA difference on the street. On the track i guess it means you can start cold with a little more pressure, so your cold tyres aren't as mushy as they come up to temp.
If you do put it in and you're somewhat disappointed at the result, try sitting on the ground with your legs either side of the tyre and push the valve right in: you might get a laugh out of it :)
lol wut?
Can't hurt, it just means you get less affected by changes in tire heat
not tru
during many race seasons i had a driver who insisted on nitrogen. so we abliged, the pressure change was markedly higher than air from a compressor.
the ONLY advantage is being able to have repeatable results. having the same air in the tyre each race. it alows for a quicker set up being able to predict a pressure for a given tyre temp. humidity is the factor with normal compressed air. since the atmosphere is 78% nitrogen anyway.
but the fact remains the pressure would raise more with n2.
if anyone has some hard data to sugest otherwise. ie: go out 30 psi with a ambiant tyre temp and come in with 30 psi with a 90 deg c tyre i will donate a leg..
n2 in a road car is the biggest WANK ever. and a complete waste of time. and the n2 has to be from a bottle. and to remove any moisture from the air in the tyre already is imposible. mayby if it was filled and deflated and vacumed 100 times you might get 100%n2 in there.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
    • Wives never seem to find things funny. Especially when they're trying to sleep, and you've found the new funniest thing ever. I've never seen someone be able to get try and be cranky with me, while they're holding back fits of laughter... 😛   Also, I tell mine it's payback anyway. She has BiPolar. So the household can get quite emotionally wild at times 😛
    • I'm not up to date on the latest, but for basic modifications like pod filter, lower springs etc you can get a modification permit at the time of inspection.  For more serious modifications you will need engineering.  Intercoolers used to fall into the mod permit rule but its been a long while since i looked it up.   Either way you will be able to get it registered, just a case of $300 vs $3k .
    • Hi everyone! I’m the new owner of a 1996 R33 GTS-T, I’ve purchased this car over from Queensland and brought it to Western Australia and I’ve found that there is a hole cut out in the engine bay for the FMIC that enters into the wheel well (fender liners are in the boot). For anyone that has had to get their car over the PITS here, will this be a major issue?
    • Yeah I've spotted this one too, whenever it's lotto superdraw week and I'm browsing car sales dot com for my new ride They must be dreaming, maybe it's worth 150k for the link to Brock?
