Hi. Bought some R32 seats the other day but they cut off a fair bit of headroom and my head is about 5cm from the roof. Dont even want to know how ill fit in with a helmet. It also doesnt help being about 6'4.
The seats are in pretty good condition with no holes etc and the drivers side cushion thing is a bit worn from going in and out, apart from that vgc.
I bought these for an S13 but never made the modifications for the bracket to fit, so they are a straight bolt on into R32 (R33 as well if its the same.) Also the seatbelt things are still Japanese and need to be changed. (I think its Jap, unless Skylines have diff seatbelts or something?)
I will swap these for a pair of S14 seats or 180SX TypeX seats as well. Otherwise, ill be happy with $230ish? I bought them a while ago for a similar price and they sat in my room for ages untill i decided to fit them and find out they cut off a fair bit of headroom.
Note. The seat in the pic is not mine, but thats what they look like. Ask anyone, and they will tell you this is a very nice seat. Would love to keep but its annoying hitting my head on my roof all the time.
Cheers.
https://www.sau.com.au/forums/topic/39030-r32-gts-t-seats-for-sale/
My car originally came with an awesome bride seat but it was sold. Bit of a **** trying to fit into that thing, my knees were right up against the steering wheel and i could hardly move.
I think ill just stick with S13 seats then, heh.
Anyone want these seats? Am i asking too much?
Price drop to 200 for the pair.
Cheers. Yeah i think its the same pattern as the seats in the pic, if not very similar. I think mine are in better condition too :D
Anyway, no idea how much it would be to get them to Adelaide, but im guessing not cheap. Can probably find a decent pair for that price over there as well? If you really want ill send them, but just look over the other option.
I will try my luck on NS as well, thanks.
    • Here's one I help build and tuned a decade ago, Garrett  GTX3071R Gen 1, T3 twin scroll 0.83 rear housing. Went from larger 272 cams down to smaller Tomei Poncams to help with the low end. S13 non VCT motor. Car was purpose built for the track, hence low down was the focus. Note the actual dyno chart shows lower boost, however the EBC and boost gauge showed 1.9Bar (Ignore the torque, I was young and didn't know how to set derived torque)
    • I’m doing some side developments on SR20det S13 engines, its one my hobby cars used it to compare flow capacity of some smaller size wheels. SR20det is one of another JDM legendary engines I'm sure there are plenty of SR enthusiasts on this forum, I will share results some common turbo configurations here. a quick run down of what the car is: Wide body 180sx Type X with black top engine (blue). It has: Stock bottom end Haltech 1500 ECU 5-0 motorsports trigger kit Kelford SR20DET Beehive Spring with Titanium Retainers Kelford Cams SR20DET S13 188-B 268/272 Cams G25-660 Turbocharger in T2 .64 rear housing internally gated ARP Head studs MLS head gasket 1000CC ID injectors Walbro 450L Fuel pump Front mount cooler kit JJR’s 3 inches turbo back exhaust (its too short for the 180sx it had to be extended) Pump 98 fuel Hub Dyno tune So far made 270rwkws at 22psi full boost by 4500RPM. Engine is very knock limited hence a pretty bad looking top end. From previous experiences it seems like SR20dets are happier with bigger size turbine, some thing like a GT30 would make way better top end, but on same time response is lost. It won't be a problem with S15 VCT engines. I'll be testing alternative turbine housing, turbine wheel and possibly dump pipe options for extra flow to resolve the problem and of course E85 would resolve all the issues.
    • Awesome writeup and details. Thanks for sharing the story so far. I can relate to parts of it with my previous car and some of the issues I had to deal with.
    • Wow the colour matched hard top completely transforms the car. Are there any nice front lip options for the car or is that off the table?
    • Generally yes but for some reason I've been ruthless this time around!  I might even need to do another tip run after the way I've finally been able to hit the delete button on shit I've stepped over, stepped around and tripped over for the past 10 years!
