  • Replies 42
I'm coming up on my 2nd oil change on my stockish 34. I've used Royal Purple in all changes, in all cars prior. But I would like to give Gulf Western Syn X 6000 or Motul 8100 X-Cess a go. Cheapest I've found for what you are interested in are...
Royal Purple HPS: $70/5 quarts (4.73L) from performanceclub.com
Motul 8100 X-Cess: $75.99/5L from justjap.co
EDIT: Also, just stumbled across this; If you're a member of RACQ, you get 20% off prices store-wide in Repco until the end of February. So go get some stuff. Or get your mum to. lol
For Those of you using Royal Purple, this might be of interest.
http://www.amazon.co...9782201&sr=1-33
And
http://www.amazon.co...9783234&sr=1-17
that works out @ $56.30AUD per 4.7L and you will get 4 changes from the 5 Gal.
Not bad a all.
Edited by Missileman
If you run Motul, my local Repco is clearing it out and replacing it with Gulf Western. Not sure if its the other stores too?
I've noticed no difference between the Valvoline semi synth I was using and the Motul 300v I dropped in at the last change. I have one more change worth of 300v then I'll be trying the new Gulf Western Syn X 6000, as by then I should be on e85.
Not bad a all.
add 100 for shipping and tax... still works out cheaper though
I'm pretty sure that figure I quoted was for the 10-40W and included shipping,
Add some to you cart and begin the checkout process and see what you get.
Mike.
Mike.
thats what i did, i was one click off buying it
it says free shipping but theres no way in hell they are goin to ship 5 gallons of oil from the US to Aus for free
Strange, my cart came up with $133 + $100.60 for 6-18 dat shipping?
It ticks while cold, goes away at operating temperature in a few minutes. No knocking (thank goodness). A lot of the guys here in the forums use 40w while I have been using 30w for almost all of my cars so I am wondering if I should stick with 40w. Thanks :thumbsup:
On the topic :)
Maybe stick with the cheaper one of the two? Both are great oils and with regular oil change, there won't much difference between the two I think tbh.
    • Thanks for the explanation, I'll sleep a little smarter tonight! Cheers.
    • Being this happened about 4 years ago, i honestly forget exactly what is was, but I wound bringing to Simon at SR Werks when he was here in NY. He was able to properly diagnose and repair. I believe it had to do with the harness behind my dash.
    • It's because the air comes in over #3 & #4. The two "dead" ends of the plenum are at #6 & #1, with #6 being a little more "compromised" (Sorry about all the quote marks) than #1, due to the shape. So you get the dead end effect at #6 & #1 where dynamic pressure converts to static pressure, likely causing the air flow to be highest for these. The others are then just working in from the ends to the centre. 6 -> 1 is only valid for FFPs.
    • Cut back on the attitude champ, no one is obligated to help you. The chances of Forester owners on here are quite low, considering this forum is called Skylines Australia. https://www.subarupartsdeal.com/parts/subaru-under-cover-front~56410sa000.html ^ that picture looks wrong, because if you see the diagram, 56410SA070 looks correct. You can always check where the mounting holes are on your car, and compare them to the pictures.
    • Hey Duncan, I've always set them up from 6 -> 1. Due to slightly higher EGT's, I also add a small amount of fuel to cylinder 6 & 5. I understand why you start at 6 but curious as to why you then continue somewhat based on firing order? Thanks
