hi all
having a recent issue with the RS Four S
i think it's the clutch on the way out, but wanted to double check
the problem seems to be most evident when cruising along the engine sounds like it's almost free revving (only a little bit, almost like what it sounds like on a cold start and the revs are higher than normal operating temp idle), but the revs on the tacho don't flare or anything
i tried the 4th gear start to see if it was slipping, but the engine died almost straight away???
the clutch friction point is well off the floor (like almost all the way out, and can't be adjusted closer to the floor), so i've been told the clutch is on its last legs
any thoughts?
many thanks all :)
https://www.sau.com.au/forums/topic/390353-clutch-issue-or/
Simple test.
Drive along at say 60-70kph in third. Put the throttle to the floor then jab the clutch (quick hit in and out immediately). If the revs flare and then stay there and you don't really accelerate, your clutch is boned. If it flares then falls back pretty quickly, then it's something else.
There's no way you'll get it going in 4th.
TBH it doesn't sound like a clutch problem. I'm not sure there is a problem at all, maybe you're just not used to what your car sounds like at constant RPM.
https://www.sau.com.au/forums/topic/390353-clutch-issue-or/#findComment-6216364
What Aaron says about giving it a boot and see what the revs do is right. I've just done the R30 clutch. At 60k in 5th if I planted the foot the revs went to 4-5000. but i never went any faster. clutch plate was down to the rivets.
https://www.sau.com.au/forums/topic/390353-clutch-issue-or/#findComment-6216383
Simple test.
yeah, not sure there is a problem but it seems to be only a recent change in noise (had the car for ~ 2 years)
this sounds easier, will give it a shot and report back on the weekend
thanks guys
https://www.sau.com.au/forums/topic/390353-clutch-issue-or/#findComment-6216426
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
    • The brakes are all stock bar some DBA slotted discs and the EBC pads and braided lines. The car has brake ducts as standard but they're kinda pointed in the general direction of the brakes rather than really getting at the heat source. I guess I should hit it with an infra red thermometer after a session and see what they're at.  100%! Its just a curiosity more than anything. As I said, high temp brake fluid was such a track day rage back in the day. From people I speak to at the track and threads on here everybody has their own take on it but I'm not gonna scoff at spending a few more bucks.    OH, a quick side question - would you use brake fluid from an opened container even if the lid has been on? Eg, if you have a bottle that you opened last time you flushed, it's been tightly closed, is it still good?
