$15,000 ono
Nissan Skyline R33 GTS25T - manual
ENGINE (work by DVS-JEZ)
FMIC
Hypergear ATR43SS1.5PU turbo with braided lines
custom Intercooler piping from turbo
740cc injectors
walbro fuel pump
pod filter with JJR air box cover
z32 afm
Apexi Power FC with hand controller
Greddy Profec-b spec 2 boost controller (high/low boost switch set for 19/14psi
respectively)
0w-40 engine oil and BP Ultimate petrol 98 octane always used, serviced every 5000kms.
3" turbo back exhaust system with 4"? cannon and high flow cat
Splitfire coilpacks
Excedy Heavy Duty Button Clutch recently installed (less than 10,000kms ago, with machined
flywheel)
New battery installed 10 months ago
Sard SSQ Blow-off Valve (2 sounds)
INTERNAL
Saber boost gauge
Kenwood doubledin dvd player
aftermarket speakers in doors and two 6x9 in rear shelf
Kenwood 1000w amp
two Sony Xplod subs in a box or single sub in box, your choice
Apexi turbo timer
Original skyline floor mats in perfect condition
Limited edition DRIFT bucket seats
Air con works nice and cold
LED lights all through car including dash
Can throw in a nismo gear knob (not installed)
EXTERNAL
19" hp rims
6000k? HID lights
LED parkers
Skyline Brake overlay (reads SKYLINE when brakes applied)
GTR front bar
JJR adjustable castor arms
Negative:
Scratch on windscreen from a rock in the wiper (passenger side)
clear coat peeling off boot. barely noticeable.
For a dyno vid, please visit my youtube channel: www.youtube.com/user/xxswitchfloxx and select either hi or low boost
https://www.sau.com.au/forums/topic/390356-for-sale-r33-gts25t-series-2/
more up to date them a possible 11 months ago :)
but seriously, you know cars and you dont need the seller to get one, they SOMETIMES check the tyre tread, thats how indepth them go lol
I work on this car and can say it is extremely nice to drive and feels very tight compared to alot of skylines i work on.
Perfect daily driver and weekend warrior
    • In a few years from now, you'll regret that. It'll eat away at you, knowing the truth of the ugly hiding beneath the beautiful exterior... 😛
    • I don't think the G2 profile is particularly dangerous for the engine per se, more just are you actually ok with the turbo lag trade-offs? If the answer is yes then go for it. I personally don't think I'd be ok with it because I spend so much time at lower RPMs and I really enjoy the feeling of being able to stay in 5th gear on the highway and just roll into the throttle to get boost. Or staying in 3rd gear on "gentle canyon cruises" without feeling the turbo lag too badly. The 525 pump should be able to run flat out on factory lines but I would bet the pressure drop from pump to regulator is quite impressive. I don't know how much it would be exactly but I've seen figures like 30 psi thrown around.
    • It's interesting seeing everyone talk about what level of risk they are happy to tolerate.  Building a GTR always has a level of risk, you could be that lucky guy that drops 20k on the engine build alone and still has the thing go pop on the dyno. Life is fun like that.  The way I see it, the thing is a toy to be enjoyed. I'd be happy to turn up the power on stock motor and limit the risk with sensible tuning and engine protection. If it still goes pop, it is what it is. The car isn't a daily driver so it can happily sit while a plan is made to sort it out.  Given this thing will be a street car only, I really feel it's worth the (relatively small if managed well) risk to turn the power up to around 350KW on e85.  I don't think anyone getting into the skyline game now is doing it out of logic. Surely it is a purely emotional decision so I'm not sure how important it is to think about the engine build logically. The heart wants what it wants.  @joshuaho96 little note for Josh, I run my 525 pump flat out all the time and through the factory lines without any issues. (excluding the melting connectors, that's sorted now. we'll pretend it never happened lol)
    • But the Nexus S3 is very expensive and won't be as purpose-built for the application as a separate electronic boost controller :^) More seriously my pet issue here would be that the Walbro 525 running at 100% duty cycle is going to require more FPR than the stock setup can handle. I'm also pretty sure from what I've seen elsewhere you might want to slow down the pump regardless unless you're going to come up with some way of upsizing the fuel lines coming from the fuel tank. Factory 8mm fuel line doesn't actually flow very much if you want to keep pressure drop down between the fuel pump outlet and FPR. If you really want to "keep it simple" I would run only as much pump as you need and source a fuel pump controller to slow down the pump in the vain hope of being able to run stock-style FPRs which are pretty dinky. Or just use the HICAS lines and it should be mostly fine. OP should also really think hard about what profile they'd want out of the turbo. My pet choice here would be the G1 profile rather than anything higher power but YMMV. I already think ~stock turbo lag is pretty bad so I don't want to make it worse. In "gentle canyon cruising" I found that I spent a lot of time around 4-4.5k RPM. I also recommend DIYing labor if you're detail-oriented enough. Costs are high for labor + if you do it yourself you can be your own quality control.
    • GTSBoy is again on the money. My actual advice? Sell the car. (really). For what it's worth as is, you can sidegrade into something much better. If you care about function then this is the actual move. If you want a Skyline to perform, set aside about $100K to do it. This is NOT a typo. You will see right away these are two very different mindsets. Realistically we're talking full restomod for any Skyline still kicking around. Have an honest think about which one you are.. and what you want to do, and how much you want to invest in this (with no return).
