when you get a HKS exhaust and it says Jasma that means its considered road legal in japan
atleast AFAIK anyway, not like any of us have a japanese handbook to rules and regs lol
elrodeo666 could probably clarify if he saw this
I can't get the link I'm on my iPhone it is the type of mani I'm looking for puts the turbo between cil 1 and 2 also has a external waste port it all seems good made from 304 stainless 2.5mm thick. I was going to make one for my sr but this looks the goods even has a t3 t4 flange
yeah, I know they make those fancy manifolds tuned lenght cause it helps with spool up times etc..
But I have been wondering lately if log style made to roughly the same dimensions as the stock manifold but with larger ports/runners .
If it would actually flow better than the stock cast item ..You,d think it would have to flow as well at least..
you could mount the turbo up on a bit of an angle and have the gate path flow out underneath it..
here this will get ya started.. :)
http://www.ebay.com.au/itm/RB25-TURBO-EXHAUST-HEAD-FLANGE-NISSAN-/280816991408?pt=AU_Car_Parts_Accessories&hash=item4161ff3cb0
How much power/boost are you after, if your thinking of a log style manifold i would assume not much, maybe look into extractors and rear/remote mount the turbo, would make things a lot simpler and it would hied the turbo.
yeah thats another idea..
But why couldnt you boost it with a log??
stock mani does alright with 20psi..sometimes more
You mean stock turbo manifold or stock non turbo manifold?
The flow would slowed for a log style manifold at high boost (even at low boost but not as much), if you do a log style and then upgrade to a proper turbo manifold you will notice boost being made a lot easier and quicker with a proper styled turbo manifold V's log style, if you have the know how and tools to make a proper manifold then do it that way, if not i would go extractors and rear mount, i personally wouldnt bother with a log manifold unless its something you have sitting there and a dump pipe to suit.
I want the turbo sitting between cil 1 and 2 as there is not much room because of abs unit in the BMW for my td06 to sit. I made up a cad drawing of what I think would work well I'm not after massive power all be happy with 260 same power that was in my 32 I'm hoping full boost by 4200 18 psi. The design I'm looking at making will be the sr20 manifold reversed the turbo will sit up top allowing the gate to run underneath the mani so hiding from the unknown eye. Basically if I was to cut the flange off a stock manifold and turn it over that's ideal for me but to hard to controll being cast
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
