Now that I have your attention
Series 3 R33 GTR 5 Speed gearbox that was installed 6 months ago. Gearbox is an OEM box (not cross mission OS Giken etc) Royal Purple gear fluid used when installed. Very smooth gearbox and a pleasure to shift.
This is complimented by an Exedy Compe D Twin Plate Clutch (pull type) with chrome moly billet flywheel with less than 15,000km use and unfortunately only one or two launches, when inspected with new box installation theres heaps of meat there.
Also the OEM R33 GTR tail shaft and gearbox cross member will be included as well as OEM shifter with Nismo black Duracon shift knob.
Will sell this as complete package and will happily remove from car once deposit has been paid as I live in an apartment block I cannot have this much laying around.
Complete package will go for $2600 plus postage costs.
Will only seperate if there is a buyer for everything.
Also I have series 3 GTR rear seat complete for $100 plus post neg
Rear seat belt kit for 4 seater configuration $75 free postage
R33 GTR front brake ducts OEM plastic $50 free postage
I am more than happy to MMS pics of anything I can or feel free to PM me for more details.
Located in Townsville North Queensland
Mobile - 0438840407
Cheers Marty
Edited by Weapon
    • How's your first born doing? 😛 As for now what? Time to forget about it for 12 to 18 months while your go down a totally unrelated rabbit hole... 😛
    • Fuse taps are perfectly fine to use, especially when you're adding stuff for your own car, and so long as you're being smart about it. IE, don't throw a 30amp circuit, onto a circuit that is only a small circuit. It's best to add a small circuit, to one that is already quite large. Oh, and make sure you're not going to blow the fuses that are further upstream too! I dislike their use in other applications, such as alarms, telematics/tracking devices etc, as it's far too easy for someone to unplug them and render a system useless. Those sorts of devices I go for wiring in quite secretively.
    • Fob is all cleaned up and it’s working well!! The amount of Vegemite looking sh*t that was in there is mind blowing
    • Given it is temporary, I bought a  cheapy gauge mount (which has become enflattened) which I will screw into the existing phone mount Also a first for me; given this is a temporary install I could not think of any reason not to use one of those "add a fuse" thingies to source the battery and IGN power. I had always figured they were pretty dodgy but having a good look at them I think they are a valid option for sourcing power from an existing source without cutting
    • Finally for now, a bit more work on the transmission temp gauge. I was wondering how Raceworks do a gauge for $100 that autometer want $500 for. No idea about the accuracy of course, but they have cut a few corners that made things hard.  First one I mentioned above, the sender is physically difficult to fit and doesn't work with their own adapters (the extra fittings I used to get the sender into a hose cost more than the whole gauge, lucky I had stuff in the shed) Second, the temp sender wires are way too short. They are shown as 2.7m on the box and I know my routing was long from navigator headlight to driver's firewall back to centre console, but I had to lengthen them by about 2m total - 2 joins in each wire. Also, same with the supplied power loom, they needed about an extra 1m to get the fuse box where I sourced power. Another join in each wire since one end wasn't supplied terminated. I know they could argue that the wires might be long enough depending on situation, but when you consider parts and particularly labour, it would be a very expensive cheap gauge if you can't do the work yourself. And, only a small issue....but it would have been nice if they remembered to tap a tread onto *both* spacers they supplied for the bracket....I haven't had to use the M4 tap often!
