Selling my current setup..
Mr.Turbo built turbo.. Based on a garrett 3071r using a fj20 .63 rear housing,welded up internal gate.
Modified standard exhaust manifold for external gate.
38mm turbosmart gate,with screamer pipe.
Highflowed side feed injectors,550cc done by PJ.
Z32 airflow meter brought from JustJap.
Power FC with hand controller tuned for this setup.
Custom made dump and front pipe.
Modified intercooler pipe to suit turbo outlet.
Car made 243kw at the wheels with boost starting at 18psi and dropping to 15psi...
Very safe tune as it was getting drifted a lot.
With new boost controller holding 18psi,it was good for just over 250kw..
Very responsive setup,seeing full boost at 3700rpm
Kit has been on the car for 1.5 years now,half of which was just sitting in the shed because i crashed it,.
Reason for selling is engine blew a head gasket and looking to up grade everything at once.
Looking to sell everything together as it will be a BOLT ON KIT, I will supply everything,oil lines,water lines,dump pipe,everything i had to change to put setup on will be sold in this kit.
$2870 for everything
Contact me via PM on here or msg me on 0401865224
https://www.sau.com.au/forums/topic/390386-rb25-turbo-kit/
Injectors are high flowed JECS... Not nismo
jet2nv : The dump pipe is to suit this turbo,or any other turbo using an fj20 rear housing,has a different bolt pattern to any other turbo iv'e seen..
https://www.sau.com.au/forums/topic/390386-rb25-turbo-kit/#findComment-6217348
  • 3 weeks later...
    • Yep, pretty much what you said is a good summary. The aftermarket thing just attached to the rim, then has two lines out to valve stems, one to inner wheel, one to outer wheel. Some of the systems even start to air up as you head towards highway speed. IE, you're in the logging tracks, then as speeds increase it knows you're on tarmac and airs up so the driver doesn't even have to remember. I bet the ones that need driver intervention to air up end up seeing a lot more tyre wear from "forest pressures" in use on the highway!
    • Yes, but you need to do these type certifications for tuning parts. That is the absurd part here. Meaning tuning parts are very costly (generally speaking) as well as the technical test documentation for say a turbo swap with more power. It just makes modifying everything crazy expensive and complicated. That bracket has been lost in translation many years ago I assume, it was not there.
    • Hahaha, yeah.... not what you'd call a tamper-proof design.... but yes, with the truck setup, the lines are always connected, but typically they sit just inside the plane of the rear metal mudguards, so if you clear the guards you clear the lines as well. Not rogue 4WD tracks with tree branches and bushes everywhere, ready to hook-up an air hose. You can do it externally like a mod, but dedicated setups air-pressurize the undriven hubs, and on driven axles you can do the same thing, or pressurize the axles (lots of designs out there for this idea)... https://www.trtaustralia.com.au/traction-air-cti-system/  for example.... ..the trouble I've got here... wrt the bimmer ad... is the last bit...they don't want to show it spinning, do they.... give all the illusion that things are moving...but no...and what the hell tyre profile is that?...25??? ...far kernel, rims would be dead inside 10klms on most roads around here.... 😃
    • You're just describing how type certification works. Personally I would be shocked to discover that catalytic converter is not in the stock mounting position. Is there a bracket on the transfer case holding the catalytic converter and front pipe together? If so, it should be in stock position.
    • You talking about the ones in the photo above? I guess that could make sense. Fixed (but flexible) line from the point up above down to the hubcap thingo, with a rotating air seal thingo. Then fixed (but also still likely flexible) line from the "other side" of the transfer in the hub cap thingo up to the valve stem on the rim. A horrible cludge, but something that could be done. I'd bet on the Unimog version being fed through from the back, as part of the axle assembly, without the need for the vulnerable lines out to the sides. It's amazing what you can do when you have an idea that is not quite impossible. Nearly impossible, but not quite.
