Hey all in the process of replacing the cars lighting with LEDs and I have broken the little light the shines on the drivers and passenger power window switches.
Has anyone replaced these lights, if so is it a pain or is it easy?
https://www.sau.com.au/forums/topic/390391-interiorexterior-lighting/
Should but maybe not it's a time little orange light that shine on the window switches or it maybe a sedan thing.
Let us know how the map lights go and what to use because I plan to do this.
I wanna do the lights under the door that shine when you open them Anyone done this
you mean the skyline skuff panel? if so i am near certain there is a thread on hear explaing how to do so
i just took all my lights out to see what bulbs where in them,
easy as pie for the map light this man is my hero for that one
The floor lights/scuff plate lights i was able to just pop the whole box out using a screwdriver from ether side and the boot light has a little circle cup over it that has a clip on 1 side and a hinge on the other that was ezy as pie also.
Yeah the boot light I've done and the plate light too, they take the same globe aswell. Pulling my door cards off to get to those lights that shine on the window switches too.
Map lights front - Done
Map lights rear - Done
Plate light - Done
Boot light - Done
Step lights, full white headlights and white dash globes are next =]
    • Hey all, I'm sorry if this has been discussed before.  I have a 2008 Japanese import V36 coupe with nav but without Bose. I bought one of those AliExpress android screens, which for the most part works really well.  The only thing that doesn't work is the air con controls (well sort of) and the factory reverse camera.  The AC can be controlled fine but it doesn't report the change in temp and mode to the screen, and the volume knob/other audio controls from the panel don't register on the learning app.  I am pretty certain that the problem is the difference in the head unit between base model (Nav but no Bose) 2007-2009 coupes and anything after 2009.  Mine is the one with the blue connector all the way to the right as seen in this forum post:  The reason I think this is there is one wire left over that doesn't fit anywhere on this head unit, or in the factory screen which also uses different connectors to more recent versions.  I've seen the upgrade from OWC, and have sent the guy a message on eBay but no response yet.  I also don't particularly need the whole kit, just *maybe* an adapter for this one cable.  Did anyone else here have the same problem, or have any insight about what I can do to get this working?  I have been in contact with the seller but all they seem to be able to do is ask for more pictures and videos. Minor edit to add:  I have been researching and found a screen on Aliexpress that actually specifies my head unit in the listing, so these things do exist.  I will contact the seller to see if the wiring adapters are interchangeable with other screens.   Thanks in advance!
    • Can't go wrong with tourings/estates/wagons.
    • Oh poop ! I missed the "deposit" in your post !
    • I laughed so hard a snot bubble popped out my nose !  And seriously ! You can still buy a decent house in Western Sydney for 2 mill ? ?
    • Come on guys, they're just trying to sell their project car to scrape together a house deposit in the Western Suburbs of Sydney...
