I have a 25G Stagea that is virtually a S2 R33. The brakes are a PITA> Awhile back the ABS light came on and is still on. Then the hand (foot) brake would not disengage so it was disconnected. Car went OK and stopped OK. Now there is a constant buzzing coming from the ABS unit on the firewall. It even buzzes when you switch off and take the key out.
Has anyone got any clues?
Also have read that Drifters disconnect the ABS. Can this be done by just pulling the fuses in the engine compartment? And what effect will it have when driving normally?. I want to get it fixed properly but will have to drive from Tamborine to the Coast. Is that dangerous?
Hope you can help.
https://www.sau.com.au/forums/topic/390410-abs/
My opinion would be not to drive it til you can get it looked at. If you apply the brakes in an emergency situation, they may not work effectively or may fail completely. Your foot brake would not be the cause for any of the problems you are having, as it works via a cable that runs to the drum inside the rear discs and activates a pair of brake shoes. Either the ABS module is at fault or there could be problems with wheel speed signal to the module.
https://www.sau.com.au/forums/topic/390410-abs/#findComment-6218450
    • Hey @Butters, did you end up getting this clutch in ? I have just ordered to a uniclutch track to go in my getrag 6 speed that’s in my BNR 32
    • I know you don't want to hear this comment, but I can't not say it.  I just can't see 200kw being worth the time and effort. Its like guys with NA cars, putting in headers/exhaust/tune for a massive 20% jump in power. Great, the slow car is still slow and you're down $10,000.  My vote is leave it NA or price in a gearbox upgrade and shoot for at least 300KW, preferably 350KW+.  Now you have a NC that will try to kill you from time to time and will be exciting to drive
    • Ah yep. The main message I want to pass on is, try not to get scared of ghosts when thinking about knock/knock detection.  What I mean is, healthy engines make noise. Knock is also noise. Your knock sensor and ECU combo are trying to determine bad noise from good noise based on how loud the noise is. The factory knock sensors and ECU are not good at doing this.  Modern ECU's are pretty decent at it, however I'd still say that you would want to verify that if your ECU says it's knock, that you actually listen to it and confirm that it is correct.  Are you familiar with the plex knock monitor?  https://www.plex-tuning.com/products/plex-knock-monitor-v3/ I expect you're the type of person that would be very keen to play with something like this. It is great knock detection and you can pop some headphones on and listen to what's going on.  Knock that you've deliberately induced in low load low RPM areas is not really putting anything at risk and is a great tuning/learning/verification tool.  I just thought this was worth mentioning based on the way you were talking about setting up a base map and the Haltech base map settings. There are better ways to spend your time then chasing ghosts and worrying about detonation in scenarios that it is crazy unlikely to encounter it.  I was also wondering, what ECU are you planning to get? Will it be long til you pick it up?
    • This came quicker than I thought. It ain't even 2025 yet.
    • I somehow quoted my post instead of editing it. I regret nothing.
