came here to add to a feb thread and found there wasnt one.
hope its not out of line to kick one off now?
heres 2 similar shots i took with my tiny instant camera on the way home from the gym
second one is framed better or?
in the shakespeare hotel
and on redfern st, if only i could have kept it straight and had a decent lense.
was in a hurry as i didnt want to be weird stalky camera guy for too long.
https://www.sau.com.au/forums/topic/390413-febuarary-2012/
  • Replies 72
Out of your first 2, I like the 2nd, I think because there isn't as much to try and focus on.
yeah i thought so too, nice to hear my instincts werent too off.
All those shots are beautiful fongy but that one is the most interesting, slight tilt shift? so much depth..the car practically pops out of the shot!
https://www.sau.com.au/forums/topic/390413-febuarary-2012/#findComment-6218913
Thankyou! :)
Yep slight tilt shift effect for the background to get a little more 'pop' :D
Did you take these? They're very good
I did :)
http://www.facebook.com/formnfunction
i re-post some stuff from stance nation,etc on the wall from time to time, but the rest is my work.
Edited by fongy8000
https://www.sau.com.au/forums/topic/390413-febuarary-2012/#findComment-6220827
    • Man, different parts but the same numbers is terrible @dbm7! And it doesn't help that most online shops don't list the part numbers at all. They just give a list of compatible models...
    • Slow when hot could also be because its getting more dynamic compression, OR things are getting a bit tighter once it is all expanded. If it were an earthing issue, typically I'd expect you to have it have issues all the time. Unless it's really a combination of both things. Where the higher compression, and things being a bit tighter, is giving that bit of extra load and you do need a slight clean up on the cables/connections.
    • Yeah, this is one of the most annoying things about nissan part numbers... I've got an unrelated example... Image is of the AT output shaft ~ they have the same part#, but clearly the shaft on the left is beefier design to that on the right ...the difference (essentially) is the 'lighter' shaft on the right, is for engines up to RB25DE (this includes RB20 variants) : the shaft on the left is for RB25/26DET(T)....are they interchangeable? Yes...but obviously one shaft is going to be stronger than the other...and, the lighter shaft is around USD115, but the heavier shaft closer to USD150...same part#... ...epc-data usually tells a tale ~ the amayama listing for 39100-23U60 has a note "Longest side is between 60 and 105 cm" ; no such info is there for 39100-23U70 ...and given the great disparity in price between the 2 parts, it makes me at least curious (to the point of caution) where the 'extra money' went? ...ie; these 2 parts have a cost difference that (to myself at least) isn't explained by 'plastic boot'...ie; with amayama there's AUD700 price difference ...plastic versus rubber?...I'm not seeing it like that...and 60cm ~ 105cm...??...that's a huge disparity....something hinky going on here... I'd try searching by VIN, not model... /2cents
    • I don't know for sure, but I'd expect them all to be interchangeable given the diff end and hub end don't move/change between any C34 series. Often Nissan will change part numbers and the aftermarket follows those year ranges; but the original part number change doesn't mean other parts won't fit. The change could be a change in material, internal parts or even just supplier. For example, all the RB gearbox to engine bolts are no longer available and there is a new part number instead. The only change is they went from cadmium plated bolts to zinc plated due to the issues manufacturing with Cadmium. They look different but work the same.
    • One year is a bit concerning. Did you try contacting GSP? It says 5 year warranty on the box if I remember correctly. I'm also running their driveshafts on my S2 Stagea.   You could check the part numbers on Amayama for your year. Here's the link for my 1998 which gives the 39100-23U60 part number. Well, that and 39100-23U70. https://www.amayama.com/en/genuine-catalogs/epc/nissan-japan/stagea/wgnc34/6649-rb25det/trans/391 What does it say for yours?
