Yes you kinda do, without being attached to anything that vacuum hose will be sucking in unmetered air (dirt, grease and what other shit is in your enginebay)
That's not such an issue, could simply block off the hose.
Thing is, that boost sensor is wired to the ECU, which will flag DTC's and cause problems. Trust me, I am well aware of what happens when that sensor is disconnected lol.
https://www.sau.com.au/forums/topic/390415-boost-sensor/#findComment-6217708
My boost holds fine drives fine and not anything had gone wrong yet lol I can't see anything wrong with it and ps I'm also running a defi gauge and thinking it is also a boost controller because boost is just above .5 bar and smooth all the way
https://www.sau.com.au/forums/topic/390415-boost-sensor/#findComment-6218108
Trust me mate. I know how the car drives without the sensor. It is going to cause you issues that you don't 'feel' while driving, I'm telling you now. Either get it replaced, or put a 1v resistor inline to trick the ECU.
I'm currently going through the same headache.
https://www.sau.com.au/forums/topic/390415-boost-sensor/#findComment-6218202
Same issue was on my R34 as well. Its intermittent fault with sensor.
Either replace with new one or second hand for $150 the price I got from some wreck yards (bit of a rip off) or contact me to repair yours.
it is an intermittent fault in the circuitry due to bad soldering = dry joint = annoying when boost gauge works on an occassion.
I was searching on SAU to find if anyone else had issues with this. found you, Will make a separate post so ppl don't get slugged paying big money for a relatively easy fix.
Though if R32 or R33 sensors are not repairable like the r34 (well not as easy, but haven't found a faulty one yet)
my stock boost gauge sometimes dies completely when driving then comes back up after a couple of minutes. could this be a faulty sensor or instrument gauge? what would happen if the stock boost sensor fails? ermm.gif
https://www.sau.com.au/forums/topic/390415-boost-sensor/#findComment-6246736
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
