HI ALL - IT HAS COME TIME FOR ME TO ASSESS MY TOY CUPBOARD - AND MAKE SOME MAJOR CHANGES BEFORE RETIREMENT - I HAVE DECIDED TO SELL MY BEAUTIFUL 2001 GTR 34 V SPEC 2 M SPEC- SOME 4000KMS AGO - I HAD TURBOS AND ENGINE REBULIT WITH QUALITY PARTS AND UPGRADED -TO SPECS BETTER THAN THE NUR- AND HAND BUILT BY CROYDON RACING- I SPENT CLOSE TO $30K - THE CAR WAS TUNED TO RUN WITHOUT RUNNING OUT OF BREATH MY ESP IN QUEANBEYAN - FROM MEMORY SOME 310KW AT THE WHEELS- THIS CAR IS DRIVEN 1 DAY PER WEEK - NEVER IN THE RAIN - THE RAYS HAVE BEEN FITTED LAST MONTH WITH BRAND NEW SEMI MEDIUM ROAD SLICKS - NEVER USED - THE CAR HAS 19INCH RIMS FOR GENERAL USE - AS THIS RAISES THE HEIGHT OF THE CAR FOR EASY DRIVING - DRIVEWAYS ARE NOW A NON ISSUE - ASKING $85K.
https://www.sau.com.au/forums/topic/390421-gtr-34-m-spec-for-sale/
hi I hope this gets thru I am finding it hard to upload pics etc on this forum - i must be dumb- and following how the threads work
can you email me [email protected] - I can easier send all info you need - teh car is in the Garage tab as well - Millenium jade - they call it - i but it is a bright silver-
Hello,
Colour and pics please.
Cheers.
    • What can't be done with a little bit of decking board or similar timber bolted to a hub flange via 2 wheel nuts is not worth talking about.
    • I noticed something. On the tps sensor and the sensor behind the adjustment screw is adjusted towards the far left. Are these screws supposed to be centered? (this sensor was in the same position before the tune as well)  Also attached a photo of where my car usually idles at when warm (sometimes a tiny bit above that). I think I might have screwed up the calculation and it might have better than I thought lol at 750rpm still not 650rpm though.
    • So for both general interest of engine health, and to rule out any coolant/oil issues, I organised an oil analysis done on the 125,000klm oil Results below, all good, just a bit of fuel dilution which I'm not too worried about
    • This is actually a really good way of measuring what wheels fit. If only there was a similar measurement between hub face and suspension :p That said, it's probably pretty simple to actually measure it all with the wheel off the car for the rear. The front is a bit more complex but..
    • Being the top Google search result for R34 wheel-related inquiries, lemme throw down my experience. I calculated that 100mm from hub face to wheel face is about the perfect fitment for my ENR34 sedan.  I've been running 18x8.5s, ET35, with a 1" spacer. So, 8.5in to mm = 216mm. 216/2 = 108mm. 108-35 = 73mm. 73+ 25 (1" to mm) = 98mm.  If you wanna get close to this on dif widths, here are the offsets you'll want: 9" - ET around 15mm 9.5" - ET around 20mm 10" - you're crazy, but ET around 30mm All these should fit perfectly on a non-widebody, non-GTR Skyline. Note that it's probably the absolute max, and you're probably better off running a couple degrees of camber in this config, but it looks great, super flush.
