Hey, im wrecking this s2 r33 minus motor and box - all parts available otherwise.
All parts located near hornsby NSW
Ring/Text 0430849962 or Pm me ( id prefer you to text or ring)
Note: the shell is gone but pretty much everything was kept..
Yellow jacket Coilpacks $400 S2
3.5inch Exhaust Cat back 550$ mild steel, have engineer cert' supposedly measured 86dB but it was pretty quite.
GtsT brakes. Front $250, Rear $150, Package $350
Boost Controller HDi 150$ comes with all lines.
Aftermarket tail lights 200$ Or offer
As new KYB shocks Front with King springs 150$, Rear KYB+Kings 150$ Package 250$
Front hubs new castor rod bushes 200$ ( i dunno what these are worth so offer.)
R33 doors with door cards Can split 100$ each Immaculate paint and door card. has hks sticker on it though..
GTR boot lid 300$ ONO
Veilside Side skirts + rear pod things 500$ or offer good nic, pain its cracking in places
2x 18x8 +30-40 offset rims multi 5 stud PCD brand new maxxis tyres 235/30something. 300$ pair.
R33 steering rack, good nic comes with lines 150$
R33 Tailshaft, dont really know condition looks ok 100$?
Rear cradle, INC dif, hubs, shafts 600$
  • Replies 51
33 Silver fuel door 20$
Door trims, all really good nic (door seals rubbers etc.) 70$ for the whole lot.
Front seats drivers side is shabby 120$
Rear 50$
33 door lock set 100$
Parting out whole interior
Dash surrounds 30$, Centreconsole + gear surround 50$
Steering wheel 80$
Roof lining 30$ awsome cond
Map light20$, roof light thingo 30$
sun visors 20$
s2 Dash immaculate 80$
Dash Cluster 80$
Manual Pedal set 60$
Manual Clutch master 40$
Clear indicators 50$ (as new) orange indicators 20$, GT badges 50$
Airbag stuff 80$ for the lot
Washerbottle 30$, Coolant bottle 30$
Brake ABS unit 60$
Brake Master Cylinder 120$
Booster 50$
Rear thing that says skyline 30$
Make offers on everything, least i can do is say no.
If there is anything not there that you want just ask as ive probably missed a bunch of stuff.
Thanks
hey mate , i need all boot trimming except for the part on the boot lid itself , if its in good condition call or sms 0431 121 625 with a price and pics , cheers
have you got:
Boot trim (walls and floor)
aftermarket taillights
silver 's' badge
I will buy all or whatever you have of them :) PM me asap please.
    • Honestly don’t even think they stock them anymore. They are discontinued.
    • Hi all,   anyone know where I can pick one of these up for a reasonable price? I just resprayed my rear trunk due to fuel stain and my new muse spat install.    added a photo for some content 🤣👍   thanks
    • Consider a 35 too...
    • He's right ~ there is no 'magic' with stuff like this ... it is more likely that in the process of looking for the short, the loom/wire 'incidentally' got moved in the process, thus removing the short ~ now, that maybe a wire (in a loom) rubbing against the edge of some grounded metal, that's worn through the insulation, causing the (now intermittent) short to ground. If one wire in a loom has been damaged in this fashion, it's reasonable to presume that other wires beside it may have also be damaged, and now exposed...you can bet the green crusty copper corrosion will start... ...that'd be a pisser, Murphy's Law steps right in as GTS observes...but worse, something like that is easier to find when shorted...ie; unplug bulb and fuse, and put multimeter in continuity mode so you get constant beep, and carefully poke about hoping to find if some movemet of the harness stop the beeping.... ...it's still all a bit Arnie tho' ..It'll be back... 😃
