  • 1 year later...
Got a New Oil Filter Stud from Nissan today, one from a RB30, when in prefect.
For those wanting to know, car is track only, running a oil cooler which will do much better then the oil to water cooler this way I've removed plenty of the water lines and got more room.
As for you GT-T1998, you can basically do the same thing, the block on the RB25Neo is pretty much the same, the thread will be exact same, so just go to nissan and ask for a Oil Filter Stud from a RB30, I can post part number up later, cost me $19, Will be worth it.
Sorry to dig up an old thread, I think the parts guy at Nissan is starting to get the shits with me making him look up old (and imported) stuff.... Does anyone happen to know the part number for the RB30 oil stud mentioned here?
Don't know if it has been mentioned yet, but when I did mine a couple months ago I just got extra heater hose and a 1/8 bsp to 1/8 bsp extension to connect oil pressure gauge back up. Helpful to know just in case.
For future thread crawlers like myself. As the removed filter housing from my 25NEO contains the bypass valve I asked Ryco for for some suitable replacement filters with the same seal diameter and thread as the Z145A and also had built into the filter itself an anti drain back valve and also a bypass valve. They sent me this chart with ADV meaning anti drain back valve and RV meaning pressure relieving valve. I can't comment as to whether the filters are suitable for your application but it's hopefully some useful information to consider.
Edited by 3Katz
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
    • Don't do what I did, use a 300000km old housing with billet gears. The old pump probably was clearanced with saw dust, Edward Lee's special engine treatment sauce and a good odo wind back. I had oil pressure issues, then replaces pump with new housing, new billet gears and 2x track day later binned a motor due to other oil related issues due to a previous engine builder. Long story short, buy a M2 or 3 or 4 N55/S55/S58 and enjoy life.
    • Yeah. "New pump" does not have to mean "massive pump".
    • Well, can you still get an OEM pump, and by the time you're buying a Nismo/N1 etc, just buy another aftermarket pump. It's better to have the pump able to flow more if its needed, than for your pressure to drop off. At any point in time, you're replacing the oil pump in a rebuild. Aftermarket pumps are likely going to be a better economical choice, and they don't have any negatives, even if they can flow more.   Also, when you're saying "replace the pump gears" are you meaning leave a 25+ year old housing in the engine with unknown wear, and just put new gears in? As that sounds silly to me, especially if you do have that minute amount of wear, that means your new pump gears now have a little bit more clearance beside them, which means, whelp, you may not get to build a lot of oil pressure or make a lot of flow.
