Hi everyone :)
R31 owner here, Mitchell is my name and i have ben enjoying
all things Nissan on this site.
I love my skyline which is totally stock apart from extractors and window tint, I have
had 5 wonderful years with her. She is part of our family but sadly the number
of people she can carry has been exceeded by the arrival of our 4th child.
We bought an AU Falcon wagon and converted it into a 7 seater and now it is time
to try and find my Nissan a good home.I will miss her very dearly and as i have held on to her
for more then a year after our 4thh arrived I feel it is time for her to move on to a better life
being driven and not parked up most of the time.
I am the 2nd owner and she has low k's (140800) She is an 89 gxe wagon in red duco.
You can see my add in the QLD classified section or in the cars for sale section of this website.
Great Website,Great People and Great Cars :)
CHEERS EVERYONE
Mitch
https://www.sau.com.au/forums/topic/390513-hi-from-brissie/
  • 3 weeks later...
    • Way more than 1cm. Appreciate the advice maybe I try changing the bushing first
    • IMG_8641.mov     She doesn’t sound the best but starts with out using any gas now. I just ran some injector cleaner through her. started roughly the first time after adding it but gave it the beans slowly upto 4k, Must have cleaned a few cobwebs out. another step in the right direction for the sub
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
