Right now I have an Apexi slide adjustable BOV to atmo with an RB25/30 with a GT3076R.
It sounded better before with the old high flow on medium orifice.
There was a relatively loud clean flutter that would growl deep and spook dogs.
Now with the 3076 it is set on large orifice and doesn't flutter as nice and is also really F%$#@%^loud on high boost.
When it releases the pssshhht, it's like someone is smashing a bottle right next to your head.
Now with the cops increasingly picking on us I wanna plumb back.
I don't think I can plumb back this BOV.
I've heard a few S15's getting around with a really cool high pitch flutter.
Not too loud, like a whistle lowering in pitch as it flutters.
Can anyone tell me which BOV's do this and can be plumbed.
I only track it once a year so ragged edge performance isn't a total requirement.
cheers.
https://www.sau.com.au/forums/topic/390514-best-sounding-bov/
  • Replies 40
Is running your BOV from when the car was stock an option?
I still have my stock BOV and its plumbed back, but you can still hear it pretty easily through intake and pod filter etc.
no mate,
Front face plenum and after market cold air box
Not clear what you want to acheive.
You want a noisy bov
You want it plumbed in because of the cops?
The only police objection is the noise - a bov vents only air so its not an emissions issue.
What is important? Personally I like my bov to be completely silent.
It is an emission issue, air escaping thats been metered = more fuel which means rich which means carbon. Well in NSW anyway its an actual fine not just defect. Not sure about vic
most bov have a soft or hard setting allowing for the sound to be adjusted like on the collar with the apexi, make sure you get a plumback.
i have to admit the apexi dual chamber would be one of the louder ones on the market. hks, sard or trust all have a unique sound.
Anyone that puts a BOV on for sound is just a plain f**king dickhead.
Dude,
I'm looking for a plumb back one that's quieter than what I have.
Whilst I'm at it I don't want to drive around in a farting horse.
Engine and exhaust notes are very important to some...
where do the GTR bovs sit in the engine bay?
I gather they just use a rubber hose to recirculate back, does it run under the engine or over or what?
Drivers side.
There is a plastic recirc pipe that goes under the radiator back to the intake side.
GTR BOV's are good for any application.
If you want less BOV noise, run an airbox.
Some people like BOVs, some dont. Some people like bling rims, others dont.
Just because you have a distaste towards BOVs, doesnt make this guy a dickhead.
OP, try a "dual port" design BOV. I have a Turbosmart dual port, one port is plumbed back, the other vents. I got a restrictor machined into the vented port to lessen the sound. You still get a nice sound (not overly loud, or stupid sounding), and because it recirculates to a degree, the "richness" on gear changes etc, is somewhat lessened. And, if you still have a AFM between filter and turbo, the flutter is there, but sounds low and sexy.
Not obnoxious like those "hectik bro's" in their "fully sick" VL's.
But, as i said, each to their own. Food for thought :)
Ty.
Just as illegal, yes. I agree with that definately.. I was talking in regards to the effect it has on tune/emission.
Agreed, a large portion of people buy because its marketed well. The other portion, know it does have *some* performance benefit.. Depending on the setup, of course.
Personally i have one because it decreases "flutter" coming from a system with no BOV. ie; that horrible "zuuuuu tututu" sound you get with most VL turbos. And because of the modification, it doesnt sound stupid either.
The flutter i talk about that i have, is actually the sound of the BOV fluctuating in response to the build-up of excess pressure in the intake tract.
Personally i dont like extremely loud "pssst" sounds..
Makes driving annoying.
    • Bump on this to not make another post, had a ‘head drain’ leak on me and have the engine out as we speak. Planning on just putting a new freeze plug back in , plug the tapped holes and just be done with that headache.    Now I still want to relieve pressure to allow oil to pass down the blocks returns easier. I’ve seen catch cans with multiple vents help folks with this issue on this forum.  I’m wanting to make my own. I have some pictures here of my setup if anyone can help how I should plumb and design the catch can I would deeply appreciate it !   rb25 Oil upgrades: 1.0mm restrictor n1 pump/billet gears extended crank collar  extended sump with trap doors/w welded fitting
    • The Frenchy's kit is the way to go forward. A modern compressor that weighs about 1/2 as much, is at least twice as efficient, and will do a good job on R134a. And of course the kit has everything else you need to connect it up and have it work properly.
    • Hey all , I am in the process of having the AC system in my r32 GTST converted from r12 to r134a and I’m being told my compressor has gone bad and I will need a new one. I was wondering if anybody has any suggestions for what is the best route to go aside from dropping $1500 on a new oem one? I did see that Frenchy’s performance garage offers a kit to mount a Toyota compressor, has anybody actually used this kit on their car? Or is there anywhere I could purchase just a clutch? Any help is appreciated.
    • Well, your RB20 ECU loom won't have wires for the boost solenoid, that boost sensor, and possibly one or two other things. There could be differences in seemingly random things like the charcoal canister purge solenoid, because the 25DET has to handle boost in the vacuum system and the 20DE does not. I don't know - I haven't looked. It is very likely that all the most important things are same-same, being the main sensors like AFM, CAS, etc, and the injectors and ignition. Not that you'll need the AFM for the Haltech anyway. I would suggest that you would seriously want to sit down with the pinouts for both ECUs and just go through them and highlight green what is the same, orange what is different/missing, and make a plan from there. It's not going to be difficult. It will either be the same or need to be fixed.
    • yeaaa that's why I haven't done any wiring to the stock ecu harness because I have the haltech, but then that leads me to the other question of "is the pnp harness really plug and play?" or would I have to still switch some pins/wires over because the pnp is for the rb25det neo harness, and not for the rb20de neo harness. was really hoping to find something to spoon feed me since so many people have done rb20neo + t conversions, but man this is rough.
