Right now I have an Apexi slide adjustable BOV to atmo with an RB25/30 with a GT3076R.
It sounded better before with the old high flow on medium orifice.
There was a relatively loud clean flutter that would growl deep and spook dogs.
Now with the 3076 it is set on large orifice and doesn't flutter as nice and is also really F%$#@%^loud on high boost.
When it releases the pssshhht, it's like someone is smashing a bottle right next to your head.
Now with the cops increasingly picking on us I wanna plumb back.
I don't think I can plumb back this BOV.
I've heard a few S15's getting around with a really cool high pitch flutter.
Not too loud, like a whistle lowering in pitch as it flutters.
Can anyone tell me which BOV's do this and can be plumbed.
I only track it once a year so ragged edge performance isn't a total requirement.
cheers.
https://www.sau.com.au/forums/topic/390514-best-sounding-bov/
  • Replies 40
Is running your BOV from when the car was stock an option?
I still have my stock BOV and its plumbed back, but you can still hear it pretty easily through intake and pod filter etc.
no mate,
Front face plenum and after market cold air box
Not clear what you want to acheive.
You want a noisy bov
You want it plumbed in because of the cops?
The only police objection is the noise - a bov vents only air so its not an emissions issue.
What is important? Personally I like my bov to be completely silent.
It is an emission issue, air escaping thats been metered = more fuel which means rich which means carbon. Well in NSW anyway its an actual fine not just defect. Not sure about vic
most bov have a soft or hard setting allowing for the sound to be adjusted like on the collar with the apexi, make sure you get a plumback.
i have to admit the apexi dual chamber would be one of the louder ones on the market. hks, sard or trust all have a unique sound.
Anyone that puts a BOV on for sound is just a plain f**king dickhead.
Dude,
I'm looking for a plumb back one that's quieter than what I have.
Whilst I'm at it I don't want to drive around in a farting horse.
Engine and exhaust notes are very important to some...
where do the GTR bovs sit in the engine bay?
I gather they just use a rubber hose to recirculate back, does it run under the engine or over or what?
Drivers side.
There is a plastic recirc pipe that goes under the radiator back to the intake side.
GTR BOV's are good for any application.
If you want less BOV noise, run an airbox.
Some people like BOVs, some dont. Some people like bling rims, others dont.
Just because you have a distaste towards BOVs, doesnt make this guy a dickhead.
OP, try a "dual port" design BOV. I have a Turbosmart dual port, one port is plumbed back, the other vents. I got a restrictor machined into the vented port to lessen the sound. You still get a nice sound (not overly loud, or stupid sounding), and because it recirculates to a degree, the "richness" on gear changes etc, is somewhat lessened. And, if you still have a AFM between filter and turbo, the flutter is there, but sounds low and sexy.
Not obnoxious like those "hectik bro's" in their "fully sick" VL's.
But, as i said, each to their own. Food for thought :)
Ty.
Just as illegal, yes. I agree with that definately.. I was talking in regards to the effect it has on tune/emission.
Agreed, a large portion of people buy because its marketed well. The other portion, know it does have *some* performance benefit.. Depending on the setup, of course.
Personally i have one because it decreases "flutter" coming from a system with no BOV. ie; that horrible "zuuuuu tututu" sound you get with most VL turbos. And because of the modification, it doesnt sound stupid either.
The flutter i talk about that i have, is actually the sound of the BOV fluctuating in response to the build-up of excess pressure in the intake tract.
Personally i dont like extremely loud "pssst" sounds..
Makes driving annoying.
    • I don’t really have any ideas how to set the timing on the CAS 😂, sounds like the top, sounds like it maybe misfiring as well as ticking,  got the box sorted 😌, must of been a air bubble on the clutch side
    • Use a 2' length of hose (that's 2 foot, not 2 inches) as a stethoscope to localise the source of the ticking. From cam covers? From exhaust or turbo manifold gasket? From injectors? From lower down in the engine? Etc. Use a timing light to set the timing. Put Redline Lightweight Shockproof in the box. It's not the very best thing for the box, but it will take a box that refuses to engage a gear with other oil, and make it engage a gear. I had to put it in when I installed the R33 box I have in my car. It would not select ANY gear when running. Smurf jizz made it work. That was >10 years ago and I still use it. I'm stuck with it now. Failing that - rebuild the box.
    • Well done Duncan. The fuel tank bulkhead lid is also in great condition (some of mine were stuffed). These are now out of production and good ones like that are becoming hard to come by.
    • Wow that's a steal, you've done well there.
    • Exterior LEDs R34 2Dr R34 4Dr Position Lamp T10 T10 Winker front T20S T20S side T10 T10 rear T20S S25S150 Anti-hyfla relay TYPE3 TYPE3 tail T10 T20W Stop Lamps T20W T20W High Mount T16 T16 back T16 T20S number T10 T10 trunk T10 T10 Interior LED Item No.     Map Lamp BA9S single-sided     Room Lamps T10×31     Trunk Lamp T10     meter Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     Liquid crystal section T6.5 pedestal     Winker T6.5 pedestal     High Beam T6.5 pedestal     3 SERIES METER Early T6.5 pedestal     final T6.5 pedestal     NISMO T6.5 pedestal     air conditioner Early Liquid Crystal T3     Late LCD T4.2 Short     button T4.2 Middle     Hazard SW T3 Pedestal Short     Keyring T5     Cigar Socket T5
