R34 Gtt Wheel Offset Advice
Shoujiki
Do you run coilovers? Have your rears scrubbed out when crabwalking really steep driveways? I want 265's on the rear now...
no coilovers just really really low springs and they havent scrubbed on steep driveways, only scrubs on big bumps if im going fast enough
dont get +40 pinch.gif atleast get +35 or somewhere around that
even with my 9.5 +34 i could go atleast +30 without rubbing and still they wouldnt stick out.
Hmm.. so what would you recommend out of these two:
18x8.5 +35 Front and 18x9 +32 Rear
OR
18x8.5 +35 Front and 18x9.5 +40 Rear
No guard rolling, don't want it to scrub of course either.
With your idea, would going for a +32 (even if it's 9") be a better fitment to the outer guard? Not really after "big width" rather just a nice look.
  • 1 month later...
I am having the same problem with getting my head around all the offsets etc..
Im looking at getting 19" x 9.5 +22 but im not sure if they will fit.. Everyone else seems to run 18"s only.. I just want something different..
My car has coilovers but is at about standard height.. The body kit should make it look like its a bit lower to the ground as I dont want to lower it because they wheels may not fit with out rolling the guards..
Pics would be sweet when you get it done :yes:
Running cr kai's - F: 18x8.5 + 30 (from memory) with 225 rubber R: 18x9.5 + 38 with 265 rubber.
Conservative (no rubbing issues), fill the guards with no work done, look nice. Excuse quick photo (bad quality)
Edited by TM7GTR
I could do with a bit of advise.
About to buy TE37's:
Front: 18" 8.5 +30
Rear: 18" 9.5 +40
Am I going to have any issues?
Will be fine, exactly what I am running except my rears are +38 offset. +40 is the offset of the stockies I believe
The only issue you're going to have is that the wheels have flat spokes :down:
The fronts will be fairly flat but my rears have a bit of concavity, and only 2 offset lower.
TE37's are pretty exxy though, have you looked at Varrstoens's or Rota Grids?
I have never seen 9.5s in that offset with concavity :huh:
18x9.5 +22 at the back will sort that out though :thumbsup:
:sick:
The TE37 is a proven strong, light wheel that is FAR superior to the above mentioned.
:sick:
They aren't crazy concave of course, but they are far from flat. TE37's easily one of the best ever, and the cost reflects so.
The only reason I mention it, is I've found a set for $2500 delivered, seem alright condition, in the above offset I mentioned.
So as long as +40 will fit, I'll deal with the cosmetic aftershock. At least they will fit nicely, regardless of the outter face concavity.
I hope. ;)
Boss looking wheel and that sounds like a good price.
Your fitment will be conservative and require no mods but I guess you always have the option of spacers if you want a bit more of an agressive look.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
    • Yeah, so try to post images with extensions that the internet can handle, not HEIC files which only arstyphones can handle.
