What are the chances of fitting front : 19 x 9.0, +20
Rear : 19 x 10, +10
Currently running stock suspension but soon to get bc/br coilovers. I'm hoping I don't have to do any guard work
your gonna need some guard work but they should sit nice once your on BC's
Rear : 19 x 10, +10
As per what Dom said,
To give you an idea one of my previous setups was 18x9 + 20 front with 235's which was a pretty flush fit but no guard issues.
Currently running 18x9 + 20 with 235's front and 18x10+18 rears with 265's, have had all 4 guards rolled and have no issues , but without the guard work the rear would definitely not have worked.
I have 18X9.5 +22 all round. 235/40 front and 265/35 rear (had them spare with plenty of tread).
Rear is perfect for me but there is a bit of poke on the fronts though. I have BC Racing BR coilovers and thought that they had some degree of camber adjustment, apparently not. Thinking I may need camber arms to tuck them in a little... Thoughts?
Can't seem to attach photos dammit!
Edited by chrisR34GTT
I guess I missed that my bad That's a good reference guide for me thanks for that !
Im on standard rate, which I think is 8k and 6k? Someone correct me if im wrong
yeah im on 8/6 as well, perfect for street/daily
8/6 aswell had a friend driving mine "he owns a GTT aswell and reckons theyre smooth
Just to throw in an alternative, I'm running BC BR F:6/R:5 on R34 GTT sedan, along with bigger swaybars, F&R camber arms and F castor arms. Very happy with the ride.
with + 40 offset on a 10 inch wide wheel your going to have trouble clearing your rear suspension unless you use spacers or your still on stock ride height.
id go +30 max in the rear
  • 3 weeks later...
camber is not the answer, sure it may give you some appealing "stance" but you go any more then -2 deg on the front and you'll notice your steering change and become more darty/twichy.
if your on 0 camber then by all means add a little just dont go crazy, maybe raise your front a little, (my front bars on 100mm and my cross bar under my engine scrapes when i go to fast on uneven bumpy roads) so surly you cant be much lower then me and i have no issues but then i have 18x9 +30 to give me the clearance i need in the front.
what size are your tires, could go down to a 235 if there fairly wide currently, and are you running stock castor? and do you have any rubbing at full lock?
Edited by IMPORTS ONLY
yeah, im also digging that alignment thread somewhere, im on 100mm too, same scenario with yours, it kisses the fender bit. running on 235, yeah stock castor, yep rubs at full lock with plastic guard, so i took it off, still hit it over bumpy roads, i haven't done alignment and not keen on getting harder spring for my coil
lol you running teins too, just saw ur thread
Edited by enka
i did have tein HA's but they didn't get low enough in the front so swapped to BC BR's, if you get aftermarket adjustable castor arms you will be able to bring your wheels forward to around 6 degrees which will give you enough room to leave the plastics in as well as have a better steering feel (in my opinion) and if you just whack them in easy as and take it to a place like jax quick fit they can adjust it to where you want it fast and cheap, also maybe if you go down to a 225 you might just be able to get the tire under with no scraping but depends if like the stretched look or not
  • 1 month later...
Just taking the thread on a slight tangent as I have found most of the info I'm looking for , but I saw earlier in the thread the OP was considering lenso d1r's, are they any good quality wise? I'm guessing by the price they aren't forged...
  • 1 month later...
Hi Guys
I am wondering if this will fit without guard rolling and would they sit flush. Car Gtt 34
18x9 +35 offset. Versus Raceforge 2 Rims
Tyres 235/40/18
If not please advise.
Might be a bit tight on the front.
I couldn't fit 9.5 +38 on the front it was too inset and was hitting the suspension strut.
I went for ;
8.5 +30 on the front 245/40
9.5 +38 on the rear 265/35
  • Like 2
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
