Test fitted some wheels.
F - 9 +30, 255
R - 10 +38, 295
With about 2.5 deg camber on the rear it was slightly pokey, and flush with 2 deg camber on the front.
Decided to go with,
F - 9 +35
R - 9.5 +38
RPF1s on their way from japan, hope this helps anyone looking to go big.
10588654_814795625218233_842044625_n1_zp
10585598_814803338550795_616279295_n_zps
  • 4 weeks later...
  • 3 weeks later...
I put on something similar Koya Cr Tek 18 x 8.5 +32 offset all round with Federal 595 235x 40x 18
Car is GTT r34.
Had the original wheela on it before handles excellent. No guard rolling.
  • 2 months later...
I want 18x9.5 inch all round, rears im fine with +38 but for the fronts its hard to find out exactly what offset i would need.
I would prefer no gaurd roll back can do if scraping.
Would +35 front be ok?
9.5 + 35 probably wont clear the inner suspension on the front.
You would probably need to go for a much lower offset if you want 9.5 on the front.
I went 18x9.5 +22, Volk Racing TE37SL's with 245/35/18 tyres.
Guards are rolled just to be safe and car is lowered w Coilovers.
Clears the plastic lining in the front with no rubbing at all.
Slightest poke on the front but hardly noticeable.
10834093_10153371011077571_1859539448_n_
10743558_10153312105092571_69778459_n_zp
  • Like 1
