18" wheels and anywhere between 225 and 245
18x8" +20 on a 235 tyre
18x9" +30 on a 245 tyre all around is what i run on the front and thats flush to guard no rub no scrub no issues (my car sits slightly higher then most due to my driveway).. so you should have little trouble going that all around (check my photos on previous page)
Hi all,
About to get some wheels tomorrow in the size 9,5j et+26 all around for my R34 GTT with nismo S-tune suspension.
Thread has been great help.
Looking to run 245/35/18 front and 255/35/18 rear. You think I can run this without rolling the fenders or any other guard work?
If not...what size tyre should I run
Cheers from Holland :action-smiley-069:
Edited by ThomasGTT
Hey mate. A 9.5 +26 will have a tiny bit of poke from the guards you may want to run a smaller tyre for clearance issues but you could probably get away with a 245.. my old 18x9.5 +22 had guard rub when going up inclines and full lock that was with lowered coilovers and a 235 tyre.. also worth mentioning make sure you wheels will clear your suspension arms on the front.. mine had a tiny gap between wheel and arm
Cheers good luck
Ps i had unmodified guards.. i would recommend rolling them if your car is lowered with that size wheel and offset
  • 3 weeks later...
18x9+25 would sit a little inside on the rears if anything. Perfect flush fit in my opinion is 18x9+30, even on that it'll sit in a little on the rears but nothing substantial
Edit: it would stick a little out than in, myyy bad
Edited by tiddyd
hey guys, i was thinking of going 18x9 +25 all round, was wondering if it would poke outside the guards considering the front on your ones look pretty flush
  • 3 months later...
To revive this thread, this is my R34 gtt with LMGT4's in 18x9+22 front and back.
Wrapped in 235/40/18 re003's all around.
No camber to them, guards are rolled at the front but probably didn't even need to, there's no scrub at all.
Perfect flush fitment front and back.
  • 2 months later...
More clear photos for you mate, yeah i noticed a huge improvment when i swapped..any photos of your new wheels?
Hey Artic, what front bar/kit is that? Lip looks great on it! Wheels look great also, glad to see a reference as i'll be running a similar 18x 9 or 8.5 + 30 all round when i finally get mine.
Edited by RR34GTT
Cheers bud. Its a ztune replica for gtt :)
    • Incidentally, I also put v3 of the tune on the car and did an oil change from 5w20 to 5w40 to see how it affected oil pressure in the mid to high end. I'm still happier with the thicker oil and will stick with it, but clearly the system is happy with 55psi even if I'm not!
    • So the other thing I got sorted over the weekend was Z1 oil catch can install. https://www.z1motorsports.com/z1-products/z1-motorsports/z1-q50-q60-30t-baffled-oil-catch-can-kit-p-23546.html It was a good kit, most importantly it came with preformed silicone hoses in the right shapes rather than trying to bend/join regular straight rubber hose. It did come with crappy spring clamps not proper hose clamps so I ditched them On the down side, it is made for LHD cars and RHD cars have the main ECU harness running straight through that location, I ended up bending 2 mounting brackets so the loom is up against the brake master cylinder compartment wall to make room for it....otherwise everything fit without modification Intercoolers off on both sides, but there was enough room to get everything done without disconnecting (and therefore having to re-bleed) the coolant lines. Each is mounted with 4x 12mm headed bolts, plus in and out side hose clamps (7mm headed, nice) and 3 electrical connectors on the navigator's side which were a real pain to undo (probably for the first time in 13 years).   Also one of the mounting bolts on the driver's side was cross threaded, thanks Infiniti/Nissan workshop mechanics. On the navigator's side, the catch can plumbs into the factory hose that goes from the cam cover PCV back to the intake.  This is the 2 new hoses in place. All simples and direct fit On driver's side, there is a bracket provided that mounts to the throttle body, they even provide slightly longer bolts to allow for the bracket thickness which is nice (although, they don't have captive washers like the factory bolts of course) In that pic the main loom brackets are not in place, once I had "adjusted" them across it now sits up against the panel and just clears the OCC The remaining problem with this is emptying it; currently you have to remove the 3x m4 bolts that hold it to the bracket and both banjos to remove it (probably dropping the banjo washers at the same time) pull it apart to empty then replace. I do have some fittings coming for a remote drain from underneath that will also add a little capacity...it is very small and will need to be emptied every oil change to be sure.
    • Noise sounds to me could be either wheel bearing related (have had similar from bearings going) or that tail shaft is still loose. Or something like a heat shield touching the tail shaft.
    • You wouldn't get away with saying the opposite, if you were there.
    • Do some wool fluff testing on the vents
