18" wheels and anywhere between 225 and 245
18x8" +20 on a 235 tyre
18x9" +30 on a 245 tyre all around is what i run on the front and thats flush to guard no rub no scrub no issues (my car sits slightly higher then most due to my driveway).. so you should have little trouble going that all around (check my photos on previous page)
Hi all,
About to get some wheels tomorrow in the size 9,5j et+26 all around for my R34 GTT with nismo S-tune suspension.
Thread has been great help.
Looking to run 245/35/18 front and 255/35/18 rear. You think I can run this without rolling the fenders or any other guard work?
If not...what size tyre should I run
Cheers from Holland :action-smiley-069:
Edited by ThomasGTT
Hey mate. A 9.5 +26 will have a tiny bit of poke from the guards you may want to run a smaller tyre for clearance issues but you could probably get away with a 245.. my old 18x9.5 +22 had guard rub when going up inclines and full lock that was with lowered coilovers and a 235 tyre.. also worth mentioning make sure you wheels will clear your suspension arms on the front.. mine had a tiny gap between wheel and arm
Cheers good luck
Ps i had unmodified guards.. i would recommend rolling them if your car is lowered with that size wheel and offset
  • 3 weeks later...
18x9+25 would sit a little inside on the rears if anything. Perfect flush fit in my opinion is 18x9+30, even on that it'll sit in a little on the rears but nothing substantial
Edit: it would stick a little out than in, myyy bad
Edited by tiddyd
hey guys, i was thinking of going 18x9 +25 all round, was wondering if it would poke outside the guards considering the front on your ones look pretty flush
  • 3 months later...
To revive this thread, this is my R34 gtt with LMGT4's in 18x9+22 front and back.
Wrapped in 235/40/18 re003's all around.
No camber to them, guards are rolled at the front but probably didn't even need to, there's no scrub at all.
Perfect flush fitment front and back.
  • 2 months later...
More clear photos for you mate, yeah i noticed a huge improvment when i swapped..any photos of your new wheels?
Hey Artic, what front bar/kit is that? Lip looks great on it! Wheels look great also, glad to see a reference as i'll be running a similar 18x 9 or 8.5 + 30 all round when i finally get mine.
Edited by RR34GTT
Cheers bud. Its a ztune replica for gtt :)
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
