Been browsing through this thread too. lots of people close but not the same as the size and offset im looking at
CST Hyper Zero 1's in 18x9 +30 on a lowered R34 GTT Coupe.
Not concerned with stance or anything just dont want to have to modify the guards. and dont want to lose much turning lock (gf loves to apply full lock when in car parks etc)
What do you think? Appreciate any insights [emoji4]
I had 18x9+22 on mine and it was lowered, slightly. You'll be good.
What tyre sizes will you be running?
What do you think? Appreciate any insights :)
Google/Bing/DuckDuckGo "r34 gtr wheels on gtt"
  • 4 weeks later...
I have a '98 R34 GT-T.
I had some Rota Grid 18x9.5 +35 and 18x10.5 +35 with 235/40 tires.
Fitment looked good but the fronts actually scrubbed on the inside suspension when turning too far. The 235's on the 10.5's were also a bit TOO stretched for my taste.
So today I just installed some Work Emotion 11R 18x9.5 +20's all around and kept the 235/40 tires. The fitment looks perfectly flush with the rear fenders but sticks out considerably on the front. VERY aggressive but it DOES fit with stock fenders and doesn't scrub. I like it. I don't intend to roll. I'm running stock GT-R shocks/struts.
Pics:
So I went to purchase my rims today but they ran out of 18 x 9.5 + 38 for the rear, but they had the 18 x 9.5 +20 instock.
I know the rear for the gtt has some room to play with, and was told the +38 was rather safe. Would i be able to run the +20 offset for the rear with 255/35 tires with no scrubing and not so much poke to get defected? Or should i go 235/40 tires?
Ultimately I want a safe but flush fitment. Yours look pretty ideal [emoji108].
Any thoughts /suggestions appreciated!
18x9 + 30 is what i run on the front no issues with a 245 tyre at all.. mind you i run my ride hight around 106mm (due to steep drive way) but you should be fine if your lower
Ultimately I want a safe but flush fitment. Yours look pretty ideal emoji108.png.
18x9.5 + 20 will be fine itl be flush, i would run the 255 tyre (235 is a bit to skinny for a 9.5 tyre imo)
  • 3 weeks later...
Any thoughts /suggestions appreciated! 18x9.5 + 20 will be fine itl be flush, i would run the 255 tyre (235 is a bit to skinny for a 9.5 tyre imo)
Should fit ok on the back at +20
I've had 9.5 +38 on the back and that fit with no guard work
Mine are +26, with 245/40's and they fit well running about 1.2 degrees camber
I have rolled my guards now however, it would probably scrub without rolling the guards
Will most definitely poke a little, mine poke about 1-2mm unless you run more camber I guess
235's pretty narrow on a 9.5, I've got 245's all round and I wouldn't want any more stretch - not a fan of the massive stretched look
Update: all wheels fitted with re003 235\40
18 x 8.5 + 30 front
18 x 9.5 + 38 rear
Pleased with the front, the rear maybe too much tuck into the body. Considering reducing camber in rear so fitments looks better but it's not a big deal.
I've been told that the tire sizing 235\40 for 9.5 was acceptable and then others saying it's not ideal etc etc been really conflicting. Did a little research and most prefer not to fit 235\40 for 9.5 apart from this website and Bridgestone who said it should be acceptable. http://www.tyresizecalculator.com/tyre-wheel-calculators/wheel-rim-size-calculator
Is there anything I should be cautious about given it may be considered stretched even if it's abit?
20170103_190020.thumb.jpeg.c141f607dbcae
18 x 8.5 + 30 front
18 x 9.5 + 38 rear
This might sound odd, but can you get some close up shots of how the re003's at 235/40 sit on your 9.5" rims?
From what I've seen they seem to be quite a wide fit and can't find any pics online. I'd imagine 235/40/18 would be priced reasonably also given the common size
Yeah that's the reason I wrapped it in 235\40 as it was cheaper option given Bridgestone was doing a promotion. Once these wear out I shall go proper sizing. received_10155667226972586.thumb.jpeg.16
  • 1 month later...
Has anyone managed to fit a 285,295 or even a 305 tyre on a R34GTT without having issues. I understand that i will probably need to pump the guards too. Keen to know what what offset was used. Reasons being I have an RWD car and would like to put the power down. Suspension has been setup to maximise straight line traction but I think my 265s are letting me down.
  • 1 year later...
Anyone able to help me figure out which offset this square set of work XT7’s is? Can’t find it anywhere :( 18x9.5
235/40 stretched up front, 255/35 on rear. Both seem to only just clear the coilovers
Completely eyeballing it only, I am saying they are probably +20.
I have 9.5 +27, and yours look to be sitting out about 7mm more than mine :p, and I wouldn't say they are +12's because they don't look 15mm further out than mine.
Surely the wheel says though on the back of it?
  • 3 months later...
If i were you, and haven't yet picked those wheels up, do not pick those wheels up because those rears will not fit under any circumstances you can think of for the rear under stock quarters.
5 hours ago, Ryno34 said:
I’m gonna be picking up a used set of 19x9.5 +22 and 19x10.5 +22 for my GTT.  GTR look bodykit from eastbear but stock fenders and quarters. Stock ride height for now. Wish me luck lol
Kinkstaah is right, the wheels will never fit but with stretched tyres you might be ok. You will need 235/30 for the front And likely 255/25 for the rear
i tried to get heroic and squeeze 275’s on the back but the passenger side has scrubbed away about 2mm of sidewall. With a +25 offset I’m gonn need to downsize to 265/35/18
I also adjusted the camber to negative 1.25 degrees
    • If you are fine with China turbos, Maxpeedingrods makes a bolt on turbo. Ive had mine for two summers now and it seems to be holding up ok.
    • Howdy all Im in a little predicament and wondering what everyone’s thoughts are? I’ve had my long block rebuilt and am in the market for a turbo due to my old one having metal shavings from crank bearings (cause of rebuild) go throughout the turbos oil lines and there wheel has a little play. I’m not really aiming for any power, just trying to keep it as oem as possible, but I can’t find a turbo that’s built for the stock ecu or find something that would be a standard replacement. Anyone have any ideas or suggestions
    • How's everyone going? Just a shout-out introducing myself. I'm James, I live on the north side of Brisbane. I bought an R33 that had been left to rot in someone's front yard for 14 years. Apparently, it has immobiliser/fuel issues. Long story short, it's suffering from a seized engine, plus whatever else turns up once it runs. The car is pretty good considering it sat for so long. It pretty much died after being imported. It has a bunch of Jap parts and a full Top Secret body kit. It's painted Fiat Turchese Festival, or aqua blue if you're not French. Another project to throw money at!
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that white thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
