1 hour ago, demiosdd said:
I think the rims atm from a quick measure with them still on car so might a bit off are 235/45/17 with a 17x9 +38
Well if that’s the case then it’s only a 2mm difference... to be sure you should have a look at the inside of the wheel spokes.. it will be engraved somewhere.
if you have the measurement correct then 2mm should be fine (as long as you’re not 1-2mm off the suspension lol) just make sure you also check the fronts at full lock both directions.
I just won some Work Meisters,  3 piece SP1.   Plan on seeing if they work with my GTT.   Should be interesting, lol.   Any idea what tires a guy should run?
Work Meisters S1
5x114.3
18x10+22
18x11+22
Edited by walperstyle
Work Meisters S1
5x114.3
18x10+22
18x11+22
Minimum 3 degree camber and ultra stretched tyres ? 235s and 245s
  • 2 months later...
Thanks to everyone's input here.  Been a lot of help reading through this.  I have a bit of a different situation.  I have a GTT with GTR fenders added on.  I ordered 18-9.5 +12 LM GT4s but they don't fit as I think some of the original GTT fender is in the way.  The shop is now telling me to order 18-9.5 +22 up front and 18-10 +22 for the back.  Any thoughts on this?  I don't want to end up with a second set of wheels that don't fit.  Car came with 18-10.5 +22 TE's but they were rubbing a bit so I was looking to change them out.
Thanks
Edited by stukinthe90s
misquote
(Just for future reference for other people wanting fitment suggestions)
I've got Work Meister S1 3P's on my 34 GTT.
18x9 +18p front on a 225/40R18
18x10 + 18p rear on a 255/35R18
Fitment is near perfect. Minimal camber in the rear too. Fronts I could probably have gone another half inch wider and cleared perfectly fine. Car is not sacked on its ass though as I hate guard rub. Only get a tiny bit as is if I go over a solid bump with a few people in the car. I have slightly pulled my fenders however.
  • Thanks 1
Thanks
Strange that they don’t fit. What tyres you running? I have 18x9.5 +20 on my fronts with 235 rubber and they clear easily
maybe you are running too much tyre on the front?
Otherwise you could get a wheel alignment and possibly adjust camber half a degree
The TE's have 265-40 on them.  I'm not sure what tire was put on the LMGT's when it was test fitted.  I'm having a shop handle all this for me as the car is down for a full rebuild.
A 265 wide tyre should only be running 35 sidewall not 40. This should solve the issue
  • 1 month later...
I’ve decided I rather run more tire and less offset. I’d like ro run 235/40 up front and 255-265/35 rear. Trying to decide if I wanna try to make 18x9.5 +22 square fit or go the safe route and do 18x8.5 +30 front and 18x9.5 +35 rear.
Edit: unfortunately the wheels I have picked out dont have a 18x9 option or I would opt for that for the front
Any advice? I’d like to avoid poke if I could. I know 235/40 on 9.5 will stretcn a bit but it’s not too over the top. My car also has GTR brembo’s so I gotta make sure everything clears lol
Edited by Ryno34
  • 4 weeks later...
both options will fit, the square set will look better and more chance of clearing the front brakes depending on the disk type.
  • 6 months later...
Hi Im looking at getting some work GT5 wheels in 18 x 9 +30 front and 18 x 10 +38 rear.  Car is fairly low on BC coilovers and all guards are rolled. Will the 18 x 10 + 38 clear the coilover fine??  Will it sit fairly flush or better off going a bit more aggressive offset. Don't really want to be cambering the wheels or having crazy poke. Just after a nice clean look.
Should be more than fine.
There's a lot of space in the rear of a 34 on the inside, I don't know too much about the BC's vs other coilovers back there, I have 18x9 +30 all round and have something like 40mm clearance on the inside. It'll poke a litttle on the rear, but 10+38 is a very common size for the rear of skylines in general in regards to that.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
