  • 1 month later...
Just wanted to say a big thanks to @ob1, @r34.bryan & @Gazzaa
Ended up going with some Rota's. Really happy with the result. Thanks to your kind replies and info they fit perfectly. No scrubbing or guard rolling and car is lowered. Looks 100% better.
For any other budding R34 Gtt drivers out there, this is what I went with.
F: 18 x 8.5 +30 - 235/40R18
R: 18 x 9.5 +35 - 255/35R18
  • Like 2
  • 2 months later...
R34 with Rota D2-EX in 18x9.5+18 all round.
tyres - 235/45 all round.
Fit perfect. Has BC BR coilovers set to fairly stiff. Slight rubbing on front inner plastic guard at full lock. And only rubs on the rear slightly if I hit a huge dip in the road at speed. Will probably give the rear guards a slight roll and lower more in the back.
On 07/04/2020 at 3:49 PM, r34.bryan said:
Hi, does anyone know if a 18x9.5 +22 265/35 square setup will fit a r34 gtt coupe?
I'm looking for a set of SSR GTX01 and I would like to run this size for the concave look. I don't like streched tires so thats why i chose 265/35 on a 9.5j
Hope anyone can help me.
Thanks!
Supposedly a 18x9.5 +22 will be flush fitment. I just can’t seem to figure out whether 255/35 or 235/40 is the move on tyres.
I’m hoping someone can enlighten me on that.
  • 2 months later...
I'm figuring out my setup at the moment - alignment isn't for another 5 weeks.
For the front I'm running TE37s in 18x9.5 +22. Camber arms are Cusco and they're set at the max negative setting, which is -2.2 according to the manual, but are likely around -3 with the drop.
Front tires are 235/40 Hankook V12 Evo 2s which I'm using for getting the sizes right.
Arches are rolled flat and pulled very slightly. As you can see, there was probably no need to do this.
I'm contemplating getting 255/35s up front and dialing the camber back to -1.35 (as per the manual) but it will be tight. I am currently hitting the fender liners at full lock.
Sorry the pic is portrait, I took this to send on my phone.
Dialled the front camber back to 1.35 degrees (as per the cusco manual), it's probably around 2.5 degrees with the drop. Rear camber is unknown at the moment.
Wheels: TE37 SL 9.5J, +22/ 10J +10
Tires: Hankook V12 Ventus Evo2 235/40/18 front and 255/40/18 rear
Fenders rolled flat.
  • Like 1
Thankyou for that last update, I went measuring based off your previous post (cause it looks great) and I was thinking the differential between the fronts and rears was a bit weird for it to fit so nicely.
Looks awesome dude
  • Like 1
Looks awesome dude
No worries, cheers for the appreciation.
I should probably note that the rears are hitting the bumper tabs under high compression - happened a few times on the highway. I think the toe is out quite a bit (toe in) - just from eyeballing it. The 255/40s were the fronts off my Z, they're not ideal but they fill the gap well. I'm undecided of where to go from here, possibly 265/35 rear and 255/35 front when i upgrade (hankook V12s are sh*te).
The fronts are scrubbing the liners on full lock and again under compression. I'm gonna heat them up and try to push them back, possibly try and push the fronts up with the arch roller, then I've got some weather stripping to seal the newly-formed gap between the liner and the fender.
  • 1 month later...
Did anyone manage to fit a 18 inch 275 in the back without stretching the tyre? Chasing the Performance here, so a meaty tyre is desired.
As i'm reading 255s are scrubbing the liners in the front, anyone fitted 245s? Since any visible scrubbing on the liners will get your car immediately impounded here and they check that in EVERY police control 😕
You can put huge tyres on the back with custom wheels, there's a ton of room on the inside of the R34 rear to pick up some seriously large rubber. I think I measured I had something like 40mm extra room to play with when I stuck my head under there and measured. (and I have 275's back there already)
Would need a rim with a custom offset to make use of this though.
Fronts you can run 255 without scrubbing. I run 265's up the front (265/35/18) and didn't have any scrubbing until I took it to the race track. Even then if I got creative with a heat gun I could have moulded it further away/clippied it closer to the body if I had've cared a great deal.
(I care a little deal)
Funny enough if you have wide enough guards a 285/30/18 (or 295!) will avoid liners better than a 275/35/18. But that's future talk.
  • Like 1
Is there actually no one that uses the performance of their Cars? Barely getting any information out of this thread... Seems like people love putting 235 tyres on a 18x9.5 Rim... (My GFs Mini Cooper has bigger tyres btw.)
Trying to figure out which size and offset i should order my Volk Ce28n in is a nightmare, since i currently only got 255 in the back and they can't hold the power on a mountain road. Should fit beefy Toyo R888R but can't have any rubbing or scrubbing under any circumstances, full lock steering in a circle 5x at 40 km/h will be tested, else the Car gets impounded.
Got my new wheels and tires!
Wheels: Work Emotion ZR10 (front: 18x8.5J +32 rear: 18x9.5J +30)
Tires: Toyo Proxes R888R (front: 245/40 rear: 265/35)
Car: 1998 R34 GT-T coupe with stock fenders, lowered on coilovers.
Camber: front: -2.2° rear: -2.5° I will reduce camber on the rear to about -1° or -1.5° soon.
I hope this can help someone. Fitment is perfect I would say.
Thanks to everyone on this thread for your info, experiences and helping me choose the right sizes.
For those interested in my built, follow me on Instagram @r34.bryan 🤙
Edited by r34.bryan
  • Like 1
  • 3 months later...
I recently just changed the tire setup on my car. As mentioned, the previous setup was for trial purposes and I really wasn't a fan. The rear profile was just too large and it kept clipping the bumper tabs.
I'm now running Accelera 651 Sports in 255/35 18 front and 265/35 18 rear. It's clipping the liner in the front under lock but as @Kinkstaah mentioned, you can push them back with a heat gun.
Wheel specs are the same: Volk TE37SL 9.5 +22 and 10 +20 rear. If I were buying these again (I orginally bought them for my Z33), I would likely get 9.5 +22 all round.
Camber is -3 front, -2.4 rear.
  • Like 1
  • 3 weeks later...
  • 1 year later...
    • Hi, does anyone know how I can, or can a moderator remove this advertisement please.  Has been sold a long time ago and would like to remove references. Thanks.
    • There are adaptors that allow you to delete the booster and use an s15 clutch master cylinder.    if you want to keep the booster they are still available brand new
    • I visited again today: It would appear they have painted the main body of the car and some parts of some of the panels, so I can say that I now have BMW parts in my car, much to the envy of @Dose Pipe Sutututu It is still covered in dust which is quite the tease but I did look at a few circumspect spots that will be behind bumpers and such and wiped some dust away: After my repeated begging to PLEASE DONT PAINT OVER THE ENGINEERING CERTIFICATE (you have to re-engineer the entire car if they do) I see THIS: Which is great. Excellent job tbh at least to me. A better non dusty example would be the backs of the doors that have been painted: Giving a reasonable contrast between old and new (I know the old isn't clear coated on the inside of doors). The door card will well and truly cover where the old paint is, you can see in the second pic some of the black butyl/whatever shit is sticking the plastic sheet behind the door transfer that has happened since it's clearly been stuck back on. The most maddening thing about this colour is every time I saw it in the wild it looks like another colour, same with photos of many cars with the same colour looking wildly different in every photo anybody ever takes and this is no exception. But stand a little further back and it suddenly looks dark AF. I did tell them when I was discussing which of the 70 million charcoal colours to choose from (a porsche one, a BMW one, or a R32 GTR one etc) that if they just ignored me and chose one at random I would probably never notice. Maybe they did. But the colour is supposed to be B39 (BMW Mineral Gray). Boring I know, but the R34 sedan (to me) really shows off it's boat-ness when you paint it in a bright colour like bayside blue or white or whatever else. I do have a fondness for AR2 Nissan Red, but decided against that because it'll have pretty odd contrast to random bits unpainted (like engine bay, bits of trim etc, and maybe it'll fade). And people will always fkin comment on AR2. Everything remains super dusty. I have tracking numbers for the new heads, as well as some Improved Racing goodies, but they probably will be a next year thing by the time they end up on the car. I did some maths on the heads and I know why nobody goes to this extent in Australia, because it's really not worth it, given I could have just CNC'ed my current heads, bought a FAST102/TB and used my current rocker/spring/cam combination and get a 383 stroker (or stroked a 6.0 GenIV bottom end to 6.6L) built for the same price of just the setup in the mail/on the floor here. Or I could have bought a LS3 and a Drysump system. And then have a complete engine to sell. Oh well
    • We just disconnected the vacuum line if I remember correctly, booster is still there. Is there a rebuild solution for the booster or a different adapter that will work for GTR chassis?
