  • 1 month later...
I want 18x9.5 inch all round, rears im fine with +38 but for the fronts its hard to find out exactly what offset i would need.
I would prefer no gaurd roll back can do if scraping.
Would +35 front be ok?
im running 18x9.5 + 22 235/40 on the fronts lowered with coilovers and it clears everything fine even on full lock, except for going up inclines(ramps and driveways) with the wheels turned then itl scuff the guard lip (mind you the car could be raised a good 10-15 odd mm to fix that because it has dropped below limit or i could just roll my guards)
it pokes a little bit and given the stretch on the tyre its really a preference on the "stanced" look it gives (it was the biggest tyre i could run under there) i never choose the "thug life"
i wouldnt run anything higher then +22 on a 9.5 wheel on the front to be safe maybe a +24mm at most but that would be pushing it
id stick with a 8.5" wheel on the front and run with the lowest offset so a +30 or some thing that should give a somewhat neat flush to lip look (maybe spacers if your into them)
  • 1 month later...
Looking at getting a set of these...
Can someone tell me if they will be too agressive for the front.
R34 GTT
http://yahoo.aleado.com/lot?auctionID=o80925603
I Have trial fitted a set to the back but not the front as time was limited.
Edited by Illest
  • 2 months later...
Need some help im thinking of getting Rota Grid R's....
Car suspension = stock, might want to lower alittle but no guard work if possible...
1. From what I've read for 18" 9.5 with an offset of 35 this will fit the rears almost perfect flush right?
2. I can't get 8.5's with the specific Rota's i want so if i was to get 9.5 what offset would sit flush for the front?
Thanks
Edited by R34R34
9.5 with + 30 would stick out a bit. Trying to fit a 9.5 on the front is hard any chance to run a 9? (i would personaly recomend a 9" on the front) 9.5 is to much because you have to run a stretched tyre to be "legal"
ok so i just did a quick calculation for you and the size for the front would also be 9.5 + 35 BUT the problem is im not sure if it will clear your springs. 9.5 on +30 will stick out about 6mm from the guard and it means youl have to probably have to runn a 235 tyre
I had 9.5 +38 test fitted on the front without a tyre and it was touching the suspension on full lock.
8.5 +30 fits perfect, no guard rub no guard work, normal tyre.
9.5 +30 will probably be quite close to the suspension especially on full lock but it may just fit. However it will poke out and may need guard work not to rub.
Maybe rota does custom orders?
Thanks soo much guys really appreciate your help... I'm thinking I might do this...
Rears: 18x9.5 +35 Rota Grid R (more concave look)
http://www.rotawheels.com.au/wheels/rota-grid-r
Fronts: 18x8.5 +30 Rota Grid (more flat look)
This way I will clear the suspension...
Hopefully they can do customs it would look better with concave look at the front too
Edited by R34R34
Yeah im not to sure about the mixed matched rims, but i guess you dont really have a choice. Have you thought about saving a little extra to buy a better quailty wheel? My rota wheel cracked after 10k km under normal road use..now i have a set of rotas and a cracked wheel sitting around doing nothing haha
  • Like 1
  • 3 weeks later...
Hey I have a GTT and I'm getting 18x9.5 et15 all round 235/35/18 on the front and 265/35/18 on the rear what well I need to do to get them to fit nice like do I need to roll the guards or anything
Definitely a guard roll on the front, back might be okay(no roll) but will probably poke out a lot.
Also those tyres will be stretched on the front.
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
