R34 Gtt Wheel Offset Advice
Shoujiki
18" wheels and anywhere between 225 and 245
18x8" +20 on a 235 tyre
18x9" +30 on a 245 tyre all around is what i run on the front and thats flush to guard no rub no scrub no issues (my car sits slightly higher then most due to my driveway).. so you should have little trouble going that all around (check my photos on previous page)
Hi all,
About to get some wheels tomorrow in the size 9,5j et+26 all around for my R34 GTT with nismo S-tune suspension.
Thread has been great help.
Looking to run 245/35/18 front and 255/35/18 rear. You think I can run this without rolling the fenders or any other guard work?
If not...what size tyre should I run
Cheers from Holland :action-smiley-069:
Edited by ThomasGTT
Hey mate. A 9.5 +26 will have a tiny bit of poke from the guards you may want to run a smaller tyre for clearance issues but you could probably get away with a 245.. my old 18x9.5 +22 had guard rub when going up inclines and full lock that was with lowered coilovers and a 235 tyre.. also worth mentioning make sure you wheels will clear your suspension arms on the front.. mine had a tiny gap between wheel and arm
Cheers good luck
Ps i had unmodified guards.. i would recommend rolling them if your car is lowered with that size wheel and offset
  • 3 weeks later...
18x9+25 would sit a little inside on the rears if anything. Perfect flush fit in my opinion is 18x9+30, even on that it'll sit in a little on the rears but nothing substantial
Edit: it would stick a little out than in, myyy bad
Edited by tiddyd
hey guys, i was thinking of going 18x9 +25 all round, was wondering if it would poke outside the guards considering the front on your ones look pretty flush
  • 3 months later...
To revive this thread, this is my R34 gtt with LMGT4's in 18x9+22 front and back.
Wrapped in 235/40/18 re003's all around.
No camber to them, guards are rolled at the front but probably didn't even need to, there's no scrub at all.
Perfect flush fitment front and back.
  • 2 months later...
More clear photos for you mate, yeah i noticed a huge improvment when i swapped..any photos of your new wheels?
Hey Artic, what front bar/kit is that? Lip looks great on it! Wheels look great also, glad to see a reference as i'll be running a similar 18x 9 or 8.5 + 30 all round when i finally get mine.
Edited by RR34GTT
Cheers bud. Its a ztune replica for gtt :)
    • The two diagrams are equivalent. The R32 one is just one sheet out of about 3 showing everything in the whole car all at once. And without knowing the functionality that occurs in the modules, they are both equally opaque.
    • 8v - 2.48ms 9v - 2.15ms 10v - 1.74ms 11v - 1.41ms 12v - 1.15ms 13v - 0.99ms 14v - 0.89ms 15v - 0.82ms 16v - 0.81ms I'm running these values on my RB20 Neo with 570cc Denso R35 stock jets and it's great. Also bought a set for my Legnum VR4, love these injectors!
    • Thanks for your reply,  Those blue/green wires running to the actuator aren't attached to anything, so I'm not sure how the central locking is still working. I will have to take a good look tomorrow, I don't have the car with me. After googling it seems like a pretty common aftermarket actuator which even uses the same green/blue wires the immobiliser required. i'll test everything tomorrow and if it's working i'll melt the solder, strip it, resolder and neaten it all up with some heat shrink. I don't have to understand it if it works hahaha I just don't want a fire/ short circuit. That R32 diagram looks more like a continuity chart? Can you make sense of this form the R34 manual? 10V is probably due to very flat battery, i'll recheck as well tomorrow, I did have to jump start it haha. Thanks again!
    • So, COM doesn't mean comms. It means common. What common itself means will depend on the type of device. For a two directional actuator (ie, one that can push and pull on the same output rod) then the common will typically just be the earth connection. There will be at least 2 other wires. If you put 12V on one of the other wires, then the actuator will push. On the other 12V wire, it will pull. Can't quite make out what is going on with the wiring of your actuator. It appears to have several wires at the actuator plug, but there only appears to be 2 wires where its loom approaches the door control module, with at least one of the others cut off. I don't know these actuators off by heart. I'd have to look at a wiring diagram for one before knowing what the wires were about, and that's despite me having to replace one in my car not all that long ago. Just not interesting enough to have dedicated memory set aside for trivia like that any more. That actuator is an aftermarket one, not the original one, which probably died and was replaced. That might require some sort of bodge job on wiring to make it work. Although nothing should justify the bodginess of the bodge job done. As to the soldering job on the door module's loom plug. Ahhahhahaha. Yes, very nasty. Again, I cant tell you what any of those wires do. You'd need to study the R34 wiring diagram (if you can find one that shows the door module). I don't think I have any. I'd have to study the R32 diagram to start to understand what mine is doing, and again, even though I've had a problem with mine for the last 25 years (where it locks the passenger door when the driver's window reaches top or bottom of travel) I'm just not interested enough to try to to work it out. So long as it's not burning down, it's fine with me. Here's the R32 GTR diagram, which, confusingly, has rear door lock actuators and window motors on it!! As you can see, unless you understand the functions of the door lock timer and the power window amplifier, you'll never be able to work out how it works just from the diagram. I don't imagine that the R34 one is any better. Hopefully an R34 aware bod can help. FWIW, the two wires that are cut and joined look like they are both power supply - so hopefully it is not fatal to join them. The 10V you measured on the cut off free end of one of them is concerning. You'd expect 12V, and it might be the reason for the bodge job joining them together.
